skuba
Hi, is it normal for washer to be draining a little bit while it's loading to start cycle?
I often have trouble properly running the washer. The washer was here when I bought the house. We do have somewhat lower water pressure in the house. To avoid problems I usually run only very small or small loads and only cold water. Still, sometimes it runs fine. But many times it gets stuck on the "sensing" phase. I hear the water loading, but at the same time, some water draining out. Is it normal?
Sometimes, it will go into wash, but then stop after wash is complete, and I have to manually switch to start a rinse/drain cycle.
it sucks because not only I am wasting water, but it makes it very difficult to do laundry.
Don't want to buy a new washer if it won't solve the problem.
Any idea what I can do to troubleshoot?
Thanks so much
Thanks so much
