Problem with new well, output pressure drops off
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by ron in sc, Mar 26, 2007.
  1. ron in sc
    ron in sc New Member
    Mar 30, 2005
    South Carolina
    New well, 20' deep, plenty of water.
    Pump will prime and run but it will drop down to about 5 psi or less and then pump back up slowly but only to 20 psi at most.
    If I stop outlet water the pump will pump back up and then shut off as it should.
    What might be going on?
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Limited Water
    You have a limited water supplying your pump.
  4. ron in sc
    Mar 30, 2005
    South Carolina
    Could I be to deep? I have water in the hole that I we put the well point down in. It's about 5" in diameter and has water that's pretty clear all the way up to about 4' from the top of the hole.
    The well is about 10' from the marsh behind my house.
  5. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Is this a pounded-in point? Have you developed the flow on the point yet?
  6. ron in sc
    Mar 30, 2005
    South Carolina
    It's the kind of point you run down with it connected to a hose.
    I'm not sure I know what you mean you by have I developed the flow on the point yet?
  7. Wet_Boots
    Mar 23, 2007
    Metro NYC
    The screen on a well point can be clogged with particles, and forcing water back and forth through the screen can increase the open area for water to flow in. Most well points in my neck of the woods are steel, with screens that occasionally need to be cleared of particles. Most of these points were pounded into the ground with slide hammers. At the beginning of their life, these points needed 'developing' - to clear the inlet screen.
  8. sammyhydro11
    sammyhydro11 Previous member
    Dec 20, 2006
    Well Drilling-Test Borings-Water Treatment-Well an
    Massachusetts
    Sounds like you have a dug well with a foot valve on the end of your dop pipe. What is the make and model of your pump and what kind of fittings were used to plumb it together?
    SAM
  9. ron in sc
    Mar 30, 2005
    South Carolina
    I have one of those 1 1/4" PVC well points. All connections are glued. All pipe is 1 1/4"
    Pump is Myers 3/4 hp. Model #HJ75S, attached to a Wellsaver tank model #LPT7H.
    Unpluged tank last night and it held pressure, so no leaks.
    Edited:
    Is it possible I went to deep, 20'? I went that deep because my original well went dry after 23 years. It was located elsewhere on the property and not near the wetlands behind the house.
  10. sammyhydro11
    Dec 20, 2006
    Massachusetts
    Ok so you have a 5" well with a 1 1/4" foot valve in the well.I read it right this time! Is there a screen on the end of that well casing? Who installed the well and what does it produce for water?If you know what it produces for water we can rule out the well as being teh issue. Just because you see water in the well doesn't mean that it will keep up with your demand. I'm thinking that you could have a vacume leak somewhere or there is a restriction in the suction line. With a well that size in diameter a submersible pump would be perfect.
    SAM
  11. ron in sc
    Mar 30, 2005
    South Carolina
    Sam,
    It’s only 5" wide for the first 5'. I have no casing. The 1 1/4" pvc goes down with the well point that has tiny slits in it, the part with the tiny slits is 4' long.
    There is no well casing.
    Me. I did the same procedure 22 years ago for my other well. Water that it does produce is clear. Volume wise it will build pressure, but then after that is released it kind or gurgles water up at very, very low pressure.
  12. sammyhydro11
    Dec 20, 2006
    Massachusetts
    Ok,so how did you get the 1 1/4" pvc well down to 20'? What was the slot or mesh size of the well screen?
    SAM
  13. ron in sc
    Mar 30, 2005
    South Carolina
    Slit size is 10,000th.
    Well point has holes on the end to I pushed it down. I used a sand shark on a 1 1/4 pvc pipe next to it to loosen up the sand to get it down. Worked well that's why I think maybe I'm to deep.
    I pulled well point up to aobut 16' and it's pumping better now, but if I open outlet all the way pump will loose pressure and stop pumping water.
  14. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    How did you determine you have plenty of water?
  15. ron in sc
    Mar 30, 2005
    South Carolina
    It sure appears I'm wrong with that theory. I thought with water filling hole to 5' from the top there was plenty.
  16. speedbump
    Jul 15, 2005
    Riverview, Fl.
    The best way to tell is with a Pitcher Pump. Use it every five feet.
    bob...
  17. ron in sc
    Mar 30, 2005
    South Carolina
    I pulled the well point up and the area of the slits on the well point was mostly full of silt. That seems to be the problem.
    How do I deal with this situation? Do I install a casing then put well point in and fill casing with gravel or what? Pump out hole with mudhog?
    Suggestions appreciated.:)
  18. sammyhydro11
    Dec 20, 2006
    Massachusetts
    I think the well needs some developing. I would do what speedbump said and go at it with a pitcher pump. If you drop the prime here and there while developing it will loosen up any kind of silt that has built up around the screen alowing you to pull it back through once you start pumping again.
    SAM
Similar Threads: Problem output
Pumps and Tanks Well Forum & Blog. Water is life. Remote cabin water problem Feb 25, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Houston, we have a problem. Well sunk? Jan 18, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump problems Jan 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure pump problem Dec 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well problems - need help! Dec 6, 2016
