Problem with Grohe Grohmix Thermo valve?
Discussion in 'Shower & Bathtub Forum & Blog' started by mrvf, Nov 16, 2011.
  1. mrvf
    mrvf New Member
    Nov 16, 2011
    NJ
    Hello, I have a Grohe Grohmix 19229 shower faucet with a ¾†thermostatic valve 34419. It was initially installed in 1996. Gradually, over the past few years the handle became harder and harder to turn. As of the other day it became loose and spins but does not change the water temperature - you can feel that there is no grab. I’ve taken it apart and cleaned the pieces with a vinegar solution. I cannot remove the cartridge – it is stuck. The shower has no leaks or drips. The pressure is fine. There was no moisture inside the wall when I took the faucet apart.
    I checked that the pieces I could remove were intact – the teeth on the stop ring are intact – no threads stripped, no cracks. When I put the faucet back together the same thing happened – the handle is loose and doesn’t change the water temperature. I tightened the handle screw but it becomes loose again after a few turns.
    My question is, is this a cartridge issue? Or do I just need to replace the other parts – like the plastic thermostat handle?
    Thanks
  2. jadnashua
    Don't know, but I think I'd just call Grohe and see what they think.
  4. mrvf
    mrvf New Member
    Nov 16, 2011
    NJ
    Thanks - I was able to figure it out, though.
    It's fixed now and working fine.
  5. santa608
    santa608 New Member
    Apr 21, 2012
    Buenas Aires
    I am desperate!
    I have the same problem. My faucet was installed in Buenos Aires. I took it apart, and I think that the plumber when he installed it broke the green screw adjustment. and jury rigged it so that it worked for a while. How does this value work? The direction talk about adjusting the temperature with a screwdriver. but that is impossible. Ihaven 't hada proper shower in a week. Thanks
  6. jadnashua
    The internal adjustment is to calibrate the temperature readout on the handle to the actual temperature...this is normally done at the factory, but should be checked by the the installer. While I don't know, my guess is that the cartridge is toast and needs to be replaced. Does Brazil have a Grohe national rep? Call them, or you might try their distributor via e-mail (may or may not be fruitful).
Similar Threads: Problem Grohe
Shower & Bathtub Forum & Blog Grohe 47050 wax cartridge problem Feb 15, 2016
Shower & Bathtub Forum & Blog Grohe 34126 thermostatic valve problem Mar 7, 2013
Shower & Bathtub Forum & Blog Grohe Thermostat Mixer Problems Feb 18, 2009
Shower & Bathtub Forum & Blog Grohe diverter problem Sep 16, 2008
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
