problem with aquastat setting for coil
Discussion in 'HVAC Heating & Cooling' started by bbillcee, Mar 9, 2007.
  1. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    if i understand correctly the aquastat used on a boiler with a coil keeps the boiler water at a certain temp so when u need hot water it does not have to wait to get hot water
    lately hot water seeems to take a while to come....i had the aqustat at 160 and raised to 170
    it has been very cold here lately....
    would going higher on the aquastat be ok?
    or i'm wondering if its a problem with the aquastat itself
    last year i remeber the hot water meter o the hot water pipe would stay round 120 it stays around 80-90 average
    the boiler and coil is 1 year old
  2. jadnashua
    A boiler coil for domestic hot water needs the boiler to be fairly hot to work well, especially in the winter when the incoming cold water can approach freezing. Often, the thing is designed for 180-200 degrees. Yes, you can adjust it up, but it will increase fuel use, but you'll have hotter water.
Similar Threads: problem aquastat
HVAC Heating & Cooling More winter, more problems Feb 12, 2016
HVAC Heating & Cooling Does running two trunklines address the problem of trunkline duct being too small Nov 19, 2015
HVAC Heating & Cooling Mitsubishi Mr Slim cool air problem Nov 8, 2015
HVAC Heating & Cooling Possible HVAC Problem Jul 31, 2015
HVAC Heating & Cooling Duct Problems Mar 26, 2015
