Problem tub drain removal
Discussion in 'Shower & Bathtub Forum & Blog' started by mrjetskey, Jun 22, 2008.
  1. mrjetskey
    mrjetskey New Member
    Apr 11, 2005
    Texas
    I am rebuilding our guest bath.Wife wants tub changed out before I build new shower.Heres the problem ,when I went to unscrew drain from drain pipe,all four of the little cross bars sheared off,it has been in 19yrs.I had no trouble changing my wifes drain(brass) in the upstairs tub.Does anyone have any idea how I can get it out without destroying tub?perhaps heat it is a steel tub,I had a 4 way tool I made to unscrew the drains it has nothing to bite on.Any suggestions Please???THanks in advance guys!!>Marvin
  2. Terry
    Aug 17, 2004
    [​IMG]
    You can cut in a notch and use a chisel to tap it out counter clockwise.
  4. mrjetskey
    Apr 11, 2005
    Texas
    Dang that was quick!Thank you so very much between this forum and the tile your world forums ,I have been able to completely redo our 1989 home a room at a time ,saving over 85 to 100,000.00 dollars in labor.My thanks once again for your help>Marvin
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I'd make 2 cuts on opposite sides just to be able to have a second better angle possibility to avoid damage to the tub.
    Be carefull with steel tubs... They tend to rust pretty bad in that area and it may be time for a new tub.
Similar Threads: Problem drain
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Ran into a small problem replacing drain. Mar 5, 2016
Shower & Bathtub Forum & Blog Bathtub Drain problem Aug 2, 2014
Shower & Bathtub Forum & Blog Bathtub Drain Problems Jul 8, 2014
Shower & Bathtub Forum & Blog Removing Shower Drain Problem Mar 16, 2013
