problem, just installed Champion (A.Standard) and it is very lopsided.. please help
Discussion in 'Toilet Forum discussions' started by BE123, May 11, 2010.
  1. BE123
    BE123 New Member
    May 11, 2010
    themoon
    I just installed a Champion toilet.. The floor is level... The toilet is to lopsided.. When you look at it you can see how it is lopsided.. The floor is level. My old toilet never looked this lopsided. Prior to installing- I did remove the old wax ring.. What is causing this lopsided? Could it have been the size of the wax ring, or the wax ring hitting the screws- when I put the toilet on the wax ring, it lookd like the screws maybe were hitting against the toilet and not have enough room to sit?? please let me know what steps I shoujld follow to fix this, thanks
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Welcome to the club! This is a common problem with American Standard toilets. My advice is to take it back and get a refund. They go buy a Toto Drake. Better toilet by far.
  4. Terry
    Aug 17, 2004
    Gary,
    I think we're being played.
    He needs to post a picture before I'm buying it.
  5. jadnashua
    If the flange is properly installed, (i.e., not sitting high or unlevel) any toilet made for USA should fit without hitting the flange. If the wax ring happened to have a plastic horn in it, that can hold a toilet up off of the flange, preventing it from sitting level. If neither of those are issues, the toilet may be defective. If you set it on a flat surface (not on the flange), does it sit level? If not, no way will it sit flat over the flange.
  6. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    If your flange is above flush with the floor that would cause it, the old toilet could have been deeper arount the bowl and thats why it was able to sit level.
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    All you need is some 1/2" plumbers putty on the low side. You must use a left hand putty knife to spread it.
Similar Threads: problem installed
Toilet Forum discussions Flushing Problem with Old Toilet Jan 18, 2017
Toilet Forum discussions Flush problems with Toto MS970CEMFG#01 Dec 12, 2016
Toilet Forum discussions I have a real problem. My toilet is a Crane Walsun and the tank is in the wall behind the toilet. Nov 20, 2016
Toilet Forum discussions Vintage toilet problems Jul 13, 2016
Toilet Forum discussions Requesting help with Toto Entrada Tank installation problem May 15, 2016
