Problem getting full hot from faucet
Desi501
Boynton Beach, Florida
Hello, I have a somewhat strange problem. I own a single floor, 1250SF home built on a slab in Florida. In the master bedroom bath mostly, if I turn on the faucet to full hot I get warm only. If I leave it running and go to the tub 5 feet away and turn it on full hot for 3 to 5 seconds, the faucet water turns hot. I get the same issue in other rooms to a lesser degree.I have even tried shutting the cold supply off altogether and still only get warm. I have replaced the faucet with no change.
Can anyone point me in the right direction with this.
Do you have a hot water recirculation system? IF you do, the cross-over valve may be defective.
Smooky
North Carolina
A cross flow can happen at single handle shower faucets if the faucet is worn or maybe if not installed correctly. Also if you add an extra shut off on the shower that can cause this problem. (The shower valve is the most likely cause)..... A “Y” connect hose on a hot and a cold faucet can cause this problem too. There are other reasons too.
Desi501
That makes some sense. I don't recall the setup behind the wall in the shower/tub but the shower control has been there for about 7 years and the problem has only shown up in the last 6 months or so. The originally plumbing is about 35 years old.
Desi501
Smooky
North Carolina
Desi501
When you pull that part out there will be a pressure ballancing unit behind that. You will need to replace everything.
Here is a simular valve with diagrams and pictures:
https://terrylove.com/forums/index....hler-rite-temp-bath-shower-valve-k-304.41581/
Wow, that pressure balancing unit is even more money than the outer valve. Home depot seems to have both in stock. I looked upo the combo part number but Home Depot only shows the mixing block on that part number. Either way they have what I need.
