Primer line for laundry sink
Tutone
Ontario
Need to install a "T" attachment to a line for a laundry faucet without a primer valve.
Manufacturer has zero suggestions. Product made it China (of course).
The primer line is already there from the previous faucet, but no way to attach it to the new faucet assembly.
Looking for solutions PLEASE
Smooky
North Carolina
Sorry, looking at either one at this point
https://www.amazon.ca/Plumb-ACE2038LF-Add-tee-Adapter/dp/B002P3CKDK matches one of them. And if that works, this seems like https://www.homedepot.ca/en/home/p.compression-tee-valve-38-inch-x-38-inch-x-38-inch.1000725820.html could also. If 1/4 inch was good to the output, see: https://www.homedepot.ca/en/home/p.compression-tee-valve-38-inch-x-38-inch-x-14-inch.1000725821.html
But wait. It is not clear that that would do the job for you. That Add-A-Tee presumes that you have a 3/8 compression stop to hook onto. You may indeed have that. Maybe you don't.
If in doubt, I suggest that you post a photo of where you want to tap in. A "line for a laundry faucet" could mean a garden hose thread. It could mean a 1/2 inch NPT pipe. It could mean other things.
Cacher_Chick
Test, Don't Guess!
Find out where the plumbers get their stock, as they probably have a better selection than you will find shopping at the chain hardware store.
