Price Pfister single handle kitchen faucet - sticky lever
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Probedude, May 10, 2009.
  1. Probedude
    Probedude New Member
    Nov 25, 2008
    CA
    I've got a Price Pfister single handle kitchen faucet with ceramic valve innards that 'sticks' when you try to operate it. Makes trying to get the flow you want challenging as the lever sticks - breaks free - sticks - breaks free as you try to adjust flow.
    It's as if the ceramic sliding discs are too smooth and stick together (at least when I've had it apart and just sliding them with my hands this too is what's happening).
    Is the mating surface between the two discs supposed to be lubed? If so, what kind of lube?
    I'm tempted to replace this with a single handle Delta.
    TIA,
    Dave
  2. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    Ceramic Discs
    Get yourself some water proof plumbers grease and put a light coat on the disc and see if that helps. if not you may have to replace them, luck. :)
  4. hj
    Pp
    Call 1-800-PFAUCET and have them send you a new stem/core.
  5. Probedude
    Nov 25, 2008
    CA
    It came with the house, I'm not the original purchaser, don't have the receipt and their 'model # lookup' help on their website didn't help me pinpoint the model.
    Will they still send parts out if I eventually figure out the model # with no receipt and not being the original purchaser?
    Dave
  6. Probedude
    Nov 25, 2008
    CA
    update:
    Took it apart again today and used Dow Corning 111 valve lubricant on it.
    It works like a dream now!
    Wife didn't know why I was fixing it until I asked her to give it a try after I put it back together.
    "WOW!" was her response. The different is night vs day.
  7. hj
    faucet
    They may ask, but do not check who originally owned the faucet, and they can usually determine the model from your description of it to them. No receipt or proof of purchase is needed.
  8. hj
    faucet
    If the discharge was steel galvanized, the fittings WOULD be standard "pressure" fittings not drainage ones.
Similar Threads: Price Pfister
Plumbing Forum, Professional & DIY Advice Price pfister shower valves Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Price Pfister Roman tub fixture from 1988? Dec 2, 2016
Plumbing Forum, Professional & DIY Advice Leaking Price Pfister shower handles Jan 3, 2015
Plumbing Forum, Professional & DIY Advice How do I finish disassembly of this Price Pfister faucet? Dec 6, 2014
Plumbing Forum, Professional & DIY Advice Recognize this kitchen faucet? Price Pfister "Hanover" Aug 19, 2014
