BeautyFish
Hi. I just moved in to a condo that was renovated about 2 years ago. All of my other faucets (sinks and baths) are either Ikea or Delta, but this one has no manufacturer's name, marks, or numbers. My issue is that I can't get the water hot enough. Before I try to disassemble the faucet to access the mix valve (if there is one), I'd like to find some information on the web. With both main valves (the ones behind the panel on the other side of the wall) wide open, it doesn't get hot enough, and with the cold shut completely off, there is very little hot water coming out. Not enough pressure to allow me to change from tub to shower.
Today, a plumber came over and refused to work on it, as he didn't recognize the make or model. Before I fork over $500 for a new faucet and installation, I would like to make sure it isn't just a matter of adjusting the mix valve or changing cartridges, both of which I have done before. Any help or advice would be greatly appreciated.
This is the faucet:
http://imgur.com/a/BGGzm
This is the faucet:
