Pressurized Well Tank Hissing
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Eliz1, Jun 4, 2011.
  1. Eliz1
    Eliz1 New Member
    Feb 23, 2010
    Knoxville, TN
    I turned on my sprinklers this morning and noticed low water pressure. After about 15 minutes only a trickle of water was coming out of the sprinklers. I checked the tank. It is making a hissing noise and the pressure gauge is at 15. I have turned off the well pump for the time being. The tank is 5 years old. What other things do I need to look for to diagnose the problem? Or is that enough. I have been running sprinklers every day in the morming and I imagine that it has contributed to the problem.
    Thanks,
    Elizabeth
  2. drick
    drick In the Trades
    May 16, 2008
    Your pressure tank probably failed. Turning off the pump is a good idea. How old is the pressure tank?
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Ja, and the well probably ran dry too or else the pump failed.
  5. Eliz1
    Eliz1 New Member
    Feb 23, 2010
    Knoxville, TN
    Sigh.
    Time to call in the pros. And maybe take the camper to the campground.
  6. drick
    drick In the Trades
    May 16, 2008
    No, bypass your pressure switch by using a couple short pieces of wire so that the pump is wired directly to the circuit breaker. Next open the faucet to your sprinkler and then turn on your circuit breaker. (Do Not close the fAucet until you have completed this test and you turn off the circuit breaker and remove the small pieces of wire!) Does the sprinkler run? If yes you probably just need a new pressure tank. If not the pump may have failed from running the well dry or overcyling the pump when irrigating. If the pump cycled itself to death you need to run more sprinklers so that the pump does not cycle when watering or you need a cycle stop valve.
  7. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Bypassing the pressure switch is not a very smart thing to do.
    I think like you say "Time to call in the pros. And maybe take the camper to the campground." ,
    Would be a better decision.
    Enjoy the outdoors.
    DonL
  8. Eliz1
    Eliz1 New Member
    Feb 23, 2010
    Knoxville, TN
    I think it may just be time to let the grass die. After 3hrs with the circuit breaker turned off I turned it back on. The hissing apparently is just the water running into the tank. The tank eventually regained 60psi on the gauge. I figure that the well is low and it cannot keep up with watering anymore. We are having a plumber out tomorrow just to check it out so we don't have something blow up.
Similar Threads: Pressurized Tank
Pumps and Tanks Well Forum & Blog non pressurized tank(?) & winterizing ?s Sep 29, 2015
Pumps and Tanks Well Forum & Blog well water, underground plastic tank...can it be pressurized? Dec 31, 2012
Pumps and Tanks Well Forum & Blog H2OwTo Pressurized Water Tank problem Dec 15, 2010
Pumps and Tanks Well Forum & Blog pressurized water tank, pressure gauge problem Mar 18, 2010
Pumps and Tanks Well Forum & Blog Pressure tank re-pressurized, now I have sediment Oct 21, 2009
