Pressure Valve
Discussion in 'Shower & Bathtub Forum & Blog' started by sullij15, Apr 14, 2009.
  1. sullij15
    sullij15 New Member
    Apr 14, 2009
    I have a newly installed Kohler K-304-KP Rite Temp pressure balancing valve in my shower. The problem is that, even though the handle is turned all the way up, the water won't get past luke warm. The water in the sink runs hot so it seems to be just an issue with the shower. Any ideas on how to fix this?
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Behind the handle there is a temperature limit stop that needs adjusting.
  4. sullij15
    sullij15 New Member
    Apr 14, 2009
    When I took the handle off, the stop is going all the way up, the red tab connects to the black stop. Any other ideas?
  5. jadnashua
    Some valves use a screw to adjust the limits, some use a lever. You may need to pull that stop off and rotate it. The instructions should have come with the valve. If you don't have them, have you checked with Kohler to see if you can get them?
    It may become obvious if you look at the parts breakdown. There will be some way to adjust the hot volume, you just haven't figured it out yet. Another Kohler gotcha...reinvent the wheel sort of thing...they must do it 'their way'.
  6. sullij15
    sullij15 New Member
    Apr 14, 2009
    Thanks! I'll pull the instructions and see if I can make sense of it. It's def worth a shot b/c I'm tired of luke warm showers!!
Similar Threads: Pressure Valve
Shower & Bathtub Forum & Blog Best type of shower mixing valve / highrise bldg with poor pressure balance Dec 21, 2016
Shower & Bathtub Forum & Blog Two Mixet valves with different pressure...help anybody? Jan 1, 2016
Shower & Bathtub Forum & Blog Grohe 35015000 Universal Pressure Balance Rough-In valve Feb 10, 2015
Shower & Bathtub Forum & Blog Riobel pressure balance Shower Valve May 30, 2014
Shower & Bathtub Forum & Blog HELP....Shower valves/Pressure relief valves make noise - no one has an answer...yet Dec 19, 2013
