Pressure up and down, surging heads
Discussion in 'Irrigation / Sprinkler Forum' started by Jakehale, Feb 11, 2009.
  1. Jakehale
    Jakehale New Member
    Apr 26, 2006
    I just redid one zone in my system because of an addition to the house. 3 of my zones are working like they always have, good. the one I had to redo is action weird. Right now I only have two heads on that one zone. I turn on the system, the pump "pumps" up to what i call the max pressure and then cycles down, at the end the two heads are like spitting out water and then not, then spitting out then not, and so on, surging. What i did to the zone was remove about 3 heads (from 5 down to two) and instead of running 3/4" pvc all the around the house, i installed a adaptor (pvc to funny pipe) and ran the funny pipe to the two heads.
    could that be my problem? going from 3/4 pcv down to 1/2 funny pipe and only having two heads?
    thanks folks
    Jake
  2. JimLewis
    JimLewis New Member
    Feb 11, 2009
    That could be the problem. But it sounds more like a valve going bad. That's more typically the reason for surging like that.
    I would recommend first just taking apart that valve. First, turn off water to the entire system. Then, once you get the top off and guts pulled out, turn water pressure back on to flush out the valve. Next turn water pressure back off. Next thoroughly rinse off all the parts you remove and replace them like they were originally. Tighten the valve back on and then try it. That may fix your problem.
    If that doesn't fix it, replace the 3/4" pipe you removed.
    Finally, if that doesn't work then you may need to replace the entire valve.
  4. Jakehale
    Jakehale New Member
    Apr 26, 2006
    Thank you very much.
    I didnt think it would be the valve because it comes on and shuts off with no problem and the pressure holds when it isnt running, no cycling of the pump that is.
    oh well, dig the ditch back up and run the 3/4 all the way through.
    thanks again
    jake
  5. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    If the original system matched up with the performance of the pump, then it is up to you to make the reworked zone match up as well. If you remove heads, then the remaining heads now are required to flow more water, which means changing nozzles. Or you might install the removed heads into the area remaining. Overkill, so far as the coverage goes, but you reduce the run time, and you're back in balance.
  6. Jakehale
    Jakehale New Member
    Apr 26, 2006
    Well, I changed the piping a little bit. Instead of going from 3/4 down to the funny pipe, i went from 3/4 to 1/2 then to funny pipe, thinking the step-down in size would stop the pressure build. Nope. The easy fix.... I adjusted the pump. go firgure...
    thanks for the input folks!
  7. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    The problem is the pump is cycling on and off because you are not using enough water with that zone. If you have an above ground type pump, you may can adjust the pressure switch up enough to keep the pump from cycling. Of course this is the problem that a Cycle Stop Valve is designed to solve. The CSV will let you run small zones with a big pump without cycling. The CSV allows you to match the zones to the yard and not the pump. It keeps the pump from cycling and keeps you from wasting water, because you don't have to run extra sprinklers just to keep the pump happy.
  8. Jakehale
    Jakehale New Member
    Apr 26, 2006
    Never heard of a CSV.... but that is something i ned to look into. I did a google search and came up with some really heavy duty ones. Are you familar with any online places that would have them for a simple 20/50 system? Easy to install?
    thank you very much for this information, i do believe that this is my problem, I only have two heads on this one zone and before it was five. I did adjust the pump and all is good, but this sounds like a much better fix.
    thanks again
    Jake
    *** just saw your signature with your web site **** what one would you recommend for a small system (1hp pump, 4 zones)?
  9. valveman
    Mar 15, 2006
    Lubbock, Texas
  10. Jakehale
    Jakehale New Member
    Apr 26, 2006
    Much thanks!
Similar Threads: Pressure down
Irrigation / Sprinkler Forum Antisiphon valves downstream of reduced pressure backflow device Jul 9, 2007
Irrigation / Sprinkler Forum Irragation well pump pressure goes up and down May 28, 2005
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Wilkins 975xl Flow/Pressure Issues Oct 21, 2016
Irrigation / Sprinkler Forum Irrigation pressure regulator adjustment : lock nut is too tight Jul 9, 2016
