Pressure testing DWV
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jar546, Dec 21, 2008.
  1. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    OK, professional plumbers. How you you pressure test your PVC or ABS DWV systems when required for inspection?
    I think we can get a good conversation out of this subject.
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    lots of gun powder down the stack.
    BUt really we fill the whole system with water. You have test balls and caps and test plugs blocking off the openings.
  4. jar546
    Feb 20, 2008
    USA
    I am bringing this up because the IPC and IRC have a water method and air pressure test. The compressed air test seems to be the most popular but the plastic pipe industry does not allow it even though it is widespread.
    Many times on jobsites, there is no waterflow because there is a well and it is often not ready for use when the plumbing rough is due.
  5. SewerRatz
    Nov 20, 2008
    Chicago, IL
    Good point about the well. I have ran into homes that needed the DWV tested, but there was no water service yet, so I went to the village and got a fire hydrant meter and used the hydrant for our water source.
    Found this technical bulletin about air testing. http://www.pweagleinc.com/literature/tb/tb-i2.pdf
  6. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    99% of the time we use air @5lbs. Manufactureres don't like you pumping foam core pvc up past 7 lbs. Water is a huge pain in the you know what, but occasionally necessary.
  7. hj
    test
    Water. It is easier to find a leak, often at a cleanout plug, than air. And if it is a stubborn cleanout plug that will not seal, the inspector can see it and will usually not reject it. That would not be the case with air.
  8. SewerRatz
    Nov 20, 2008
    Chicago, IL
    I once caught a plumber gluing the plugs on the clean outs. I was like WTF man are you crazy?!?! Apparently he never did service work. The inspectors learned of his practice and made him go back on 100's of jobs to correct this issue.
Similar Threads: Pressure testing
Plumbing Forum, Professional & DIY Advice Air pressure testing water lines Nov 10, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing copper pipes Sep 24, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing PEX lines leading away from a ManaBloc? Feb 23, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing copper pipe add-on Dec 27, 2015
Plumbing Forum, Professional & DIY Advice Pressure Testing Shower Installation Apr 30, 2015
