Pressure Testing & Cleanouts
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by PeteSC, Nov 26, 2012.
  1. PeteSC
    PeteSC New Member
    Aug 7, 2012
    South Carolina
    I pressure tested my DWV system yesterday for leaks using a test plug and filling the drain lines with water to flood level of the highest fixture. There were a few drips from two cleanouts in the system - would Teflon tape around the cleanout plug get rid of that? Is it even something to bother with?
    Thanks.
  2. big2bird
    big2bird IBEW Electrician
    Sep 29, 2012
    IBEW Electrician
    Anaheim, Ca.
    A retired plumber told me to use wax from a cheap wax gasket. Not only does it seal, but it screws in and out rather nicely.
  4. PeteSC
    PeteSC New Member
    Aug 7, 2012
    South Carolina
    Ooohhh.....I like that idea. Thanks!
  5. hj
    They are not under pressure, unless the drain is clogged, so you don't really have to worry about them. Testing is usually done to 10' above the floor, not the flood line of the fixtures.
  6. PeteSC
    PeteSC New Member
    Aug 7, 2012
    South Carolina
    Thanks. I've understood that a little drip from the cleanout wasn't anything to fret over but in the end it really comes down to what my inspector wants to see. Same for the pressure test - inspector instructed me to test it to the flood level of the highest fixture, so that's what was done.
Similar Threads: Pressure Testing
Plumbing Forum, Professional & DIY Advice Air pressure testing water lines Nov 10, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing copper pipes Sep 24, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing PEX lines leading away from a ManaBloc? Feb 23, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing copper pipe add-on Dec 27, 2015
Plumbing Forum, Professional & DIY Advice Pressure Testing Shower Installation Apr 30, 2015
