Pressure test PEX with air compressor pressure regulator
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chuckd83, Jan 20, 2014.
  1. chuckd83
    chuckd83 New Member
    Jan 20, 2014
    Texas
    I replumbed my house with PEX and now want to pressure test it. I would rather do it with air. Uponor says to bring it up to 120 psi to condition the pipe for 30 minutes. Then take it down to 80 psi for 2-24 hours.
    Can I use my air compressor pressure regulator to do this?
    1. Connect compressor to one fitting and set line to 120 psi.
    2. Bring up to 120 psi for 30 minutes then down to 80 psi.
    3. Check pressure at second fitting for 2-24 hours.
    ??? my first time.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    There is not much volume in a supply piping system so you will want to be careful not to overdo it. Tee in a regular pressure gauge and a threaded schrader valve anywhere in the system. Make sure you are not pressurizing any fixtures or appliances! Leave the gauge in place for the duration of the test. (I would mount a gauge permanently where there is an unfinished space like a utility room or basement.) I use a regular bicycle pump with a long hose to pump up the system.
  4. edwardh1
    edwardh1 Member
    Jul 21, 2006
    South Carolina
    one risk of every "hydro" is over pressurizing the item being tested and damaging it.
    is the 120 50& above working pressure? soundes high
  5. jadnashua
    The safety pressure release on a water heater opens at 150psi...120 isn't too high.
  6. chuckd83
    chuckd83 New Member
    Jan 20, 2014
    Texas
    Thanks for the advice. As to the 120 psi comments, here are the Uponor instructions:
  7. jadnashua
    Pex-a installed with the expansion system, is IMHO, more robust than when using crimped connections. But, neither should be a problem at the pressures indicated.
Similar Threads: Pressure test
Plumbing Forum, Professional & DIY Advice How to pressure test new water lines? Nov 14, 2016
Plumbing Forum, Professional & DIY Advice Air pressure testing water lines Nov 10, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing copper pipes Sep 24, 2016
Plumbing Forum, Professional & DIY Advice Natural Gas Line Pressure Test Mar 22, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing PEX lines leading away from a ManaBloc? Feb 23, 2016
