pressure tank yes or no
Discussion in 'Irrigation / Sprinkler Forum' started by 54JVR, Jul 25, 2005.
  1. 54JVR
    54JVR New Member
    Jul 25, 2005
    If I am going to be using my well strictly for irrigation do I need to have a pressure tank? I currently have the pump wired to go on with the sprinkler system. I heard something about water hamering the irrigation system. This stuff is new to me.
    Also how critical is it for each station to have the same flow rate? Currently none of the stations are beyond pump capacity but some stations have three heads and others have four running at 3 gpm per head.
  2. hj
    tank
    If the pump runs continuously, then you do not need a tank. The purpose of the tank is to even out the on/off cycles and prevent the pump from cycling on and off constantly.
Similar Threads: pressure tank
Irrigation / Sprinkler Forum Possible to run off a pressure tank and a timer for two seperate functions? Apr 12, 2014
Irrigation / Sprinkler Forum small pump in stream - pressure switch? Tank? Jul 29, 2011
Irrigation / Sprinkler Forum Flussmatic Marina vs Pressure tank and Pressure switch Dec 22, 2008
Irrigation / Sprinkler Forum Convert propane tank to water pressure tank Jun 25, 2008
Irrigation / Sprinkler Forum System Design Decisions - Pressure Tank, Relay, Pressure Switch, Valve Placement??? May 14, 2008
