The pump is still going to cycle for every 23 gallons of water used with that 86 gallon tank. You need to figure out why the CSV is not working. The CSV was working when it left here, but something is not right now.
I have been testing all day. I have a 25S20-11 pump in the pit and with 500+ pounds pulling up on the CSV12560-1 it works fine. The minimum flow even with 20 PSI differential is .3 GPM, and I think you have 40+ PSI differential. This CSV regulates everything above 2 GPM at 60-65 PSI. Set 20' below surface that would give you 50-55 PSI when using water, and you should get plenty of time for tank fill. I do not think you need the -3 valve, especially for those drip zones with only 10 heads.
I am shipping this CSV to you today. I recommend trying it before purchasing an expensive tank that won't stop the cycling.
