pressure tank size
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by jdbeck, May 6, 2008.
  1. jdbeck
    jdbeck New Member
    May 6, 2008
    Hi folks!
    I have a question about sizing for a pressure tank.
    My current set up is a well x trol 203 and a sta-rite 3/4 hp 10gpm
    pump with a 175 ft well.
    I checked the tank this am, after noticing the pump cycling a lot and come
    to find i have a ruptured bladder.
    Since I need to replace the tank anyway, I am considering a bigger tank
    7 people ( 2 adult, 5 kids )
    The pressures were 30/50 but it was too low, so i boosted to 40/60 and
    increased the bladder pressure to 38. That was about 6 months ago, and things performed better.
    Pros / Cons appreciated.
    Thanks !
    Jeff
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    If you have a submersible pump, I recommend a Cycle Stop Valve and a smaller tank. A 42 gallon Bladder Tank equivalent should be about perfect.
    This way, you won't cycle the pump motor to death and you will also have constant pressure while the pump is running.
    bob...
  4. jdbeck
    jdbeck New Member
    May 6, 2008
    Bob,
    after looking at your page on tanks, i am still a bit confused.
    when you say 42G 'equivalent' would that be the wwt-20?
    Suppose i don't add the CSV - another whole kettle of fish as I don't
    want to pull the pump up to do it.
    What size would you estimate without the valve?
    Thanks !
    Jeff in Maryland
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Yes, the 42 gal equivalent is the PC-66 or the WWT-20. You don't have to pull your pump to install a CSV. Just install it anywhere between the pump and tank/pressure switch. If your putting one inside, go with the brass CSV1Z.
    bob...
  6. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Without a CSV, one minute of run time is required and two minutes is better. That would take a 40 gallon bladder tank for one minute, or an 80 gallon tank for two minutes. Even a two minute cycle is fairly short when you consider there are 1440 minutes in a day. Cycling is what busted the bladder in the tank you have now. 40 gallon tank would give you the minimum cycling time, 80 gallon tank cuts the cycling in half, the CSV and a 20 gallon tank completely eliminates cycling during long term uses of water.
Similar Threads: pressure tank
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Saturday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Want to change well tank pressure Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Wellpump and pressure tank mismatch? Jan 26, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Tank Jan 25, 2017
