Entropy
Good Afternoon.
My pressure tank needs to be replaced. Is this something I can do myself?
I would greatly appreciate any advise on how to change it.
I can solder myself, but I’m not sure about what to do when I have the other installed.
There are valves to ‘isolate’ the pressure tank, which I assume is a good thing, but I might have to do some cutting and moving around if I buy a larger tank. Will I have to pressurize something? Set the on / off switch? Prime the pump? Release air from the lines? Fix an air lock (where might that occur)?
This set up is in my house, there are two hoses coming out of the pump on the right side which go to the well I assume, and one that comes from the top that goes to the line which is connected to the pressure tank. Any idea what size of tank this might be? I was going to buy a brand from Canadian Tire “Diamond†are they o.k.?
Also, is it easy to “re-pack†my iron filter, is this something I can do (if so where would I buy stuff to re-pack it with, or do I just clean it out)? Any Idea on where I would find manuals for the iron filter and water softer?
I have very little available funds for this, so I would like to do it myself. Or, will I end up calling in a pro after I mess it up, and pay more .... Suggestions?
Thanks
Entropy
Thanks
Entropy
