pressure tank installed correctly?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Woodenshoe, Apr 22, 2009.
  1. Woodenshoe
    Woodenshoe New Member
    Jun 16, 2008
    Georgia
    I have a shallow well with a 1 hp jetpump and a bladdertank for my house. A couple of years ago I had a new pump installed and he also put the pressure tank in a different spot. After that the pressure in the house was a little lower than usual. The pressure switch is 30/50 and pressure tank 28 psi.
    I will include some pictures, there is a softener but that is bypassed since I am replacing it.
    The filter you see is a Rusco sediment filter that I flush weekly since I have a little sand issue.
    Is the tank installed correctly??
    [​IMG]
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    There are far better sand filters that can remove sand without having to be messed with all the time.
    There is nothing wrong with the tank install that I can see. The problem I see is right here:
  4. Woodenshoe
    Jun 16, 2008
    Georgia
    sand
    It has been working now for a year or two, I had well guys coming over and they all said I need to drill a new well:(
    What kind of sandfilters are in your eyes better, do you have any examples or links?
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    I don't have a picture of one, but a simple water softener tank with a standard in and out head with silica sand in it, can remove the finest sand and won't need backwashing for months. A simple manual backwash manifold can be made cheaply enough. I have made lots of them.
    I simply have no use for in line filters like yours or the ten inch cartridge filters the big box stores like to call "Whole house filters" what a ruse. They cause more problems than they cure.
    Gary also sells a sand filter that I'm sure works quite well.
    bob...
  6. Gary Slusser
    Retired
    Do you actually find sand in that thing, it looks to be filled with rust to me.
    It's probably coming for the galvanized well you have, and any iron in the water.
    I don't like tanks plumbed like yours is. That's because as the water comes out and the pump comes on, the water has to swap directions, and it does it again when the pump shuts off and you're still using water. That can cause water hammer. I plumb tanks off a tee as the main water line goes past the tank.
    With the water line from the well going up and then down to the pump, if you need to prime the pump, you aren't going to be able to unless you cut the line at the high point, or raise the pump.
  7. Woodenshoe
    Jun 16, 2008
    Georgia
  8. speedbump
    Jul 15, 2005
    Riverview, Fl.
    It would do the same thing I'm telling you about except theirs has an automatic backwashing head where mine was manual. I offer the same thing only with a non electronic head.
    bob...
  9. Woodenshoe
    Jun 16, 2008
    Georgia
    manual
    Yeah but yours would probably be a lot cheaper without the clack on it:)
    The only problem I have right now is that I do not have a drain in my little well house.
    The drain from the old softener that was installed was just hanging outside the wellhouse and was discharging behind the wellhouse in the woods.:eek:
    Since both the softener and the filter would have a drain how would I create a drain? Do I need to find a way to connect to the drain from the house?
    Ron
  10. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Yes, you would have to have some sort of drain to backwash it either manually or automatically.
    Unless you have a lot of sand, an automatic unit would be kind of a waste.
    bob...
  11. Gary Slusser
    Retired
    Personally I wouldn't use a "sediment" filter for sand. My sand 'filter' is a patented blow down type tank that traps the sand from getting out and then once a month or as needed, you drain water out the bottom. It also traps sediment that is heavy enough to settle out of the water stream. It's also much less expensive and comes in two sizes, you would use the mini. For more info you have to call me. Beware of the guys at your link...
    For the rust I see in your spindown 'filter', you may need a special type softener.
Similar Threads: pressure tank
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Saturday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Want to change well tank pressure Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Wellpump and pressure tank mismatch? Jan 26, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Tank Jan 25, 2017
