I am in my first house with a well. I have noticed my pressure tank getting progressively worse over the past couple years. I have tried hooking up a compressor to it and pumping it out but that didn't seem to work. It was a small compressor. I will try a bigger one if I need to.
Anyhow, currently I get a drawdown of about 3 or 4 cups of water before it cycles and I am worried about my pump. I have a schrader valve on the side 3/4 of the way to the top. The other night I tried to run it dry by leaving a faucet open and turning the pump off. That didn't seem to work, and when I pressed on the schrader valve water sprayed out. I'm no expert but I'd say that isn't good. How can I hook a compressor up to it if it's going to spray water back into the compressor?
Another thing the tank is installed only about 2 inches off the floor and I can't see a drain valve anywhere around the bottom of the tank. Can anyone tell me what I can do to temporarily fix the tank or at least get my drawdown back up to a couple gallons at least. The tank is a pretty decent size, maybe 15 inches across and 30 or 32 inches tall. Any questions that you may have, just ask and I will do my best to answer them. Thanks in advance.
