pressure switch sticks
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by pumped up, Jul 15, 2005.
  1. pumped up
    pumped up New Member
    Jul 15, 2005
    Pump runs and empties tank, bringing it down to zero pressure and water and pump stop. Pressure switch does not automatically click on to restart pump. However, when pressure switch outer case is tapped lightly a couple of times something seems to be jarred loose and switch trips and everything works fine for awhile. Happens every other day or so, getting tired of jumping out of the shower and crawling under the house. Any idea what might cause this intermittent problem and how to fix it?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    From what you said, I'de say it's time for a new pressure switch. Or if your in bug country, you may have ant's, roaches, frogs, lizards etc. in the switch keeping the points from making up. The tapping will sometimes get them together again
    bob...
  4. pumped up
    Jul 15, 2005
    Thanks for reply. Should have mentioned: pump, switch and tank only 2 months old. Installed in crawl space, bugs might be problem, I'll check under cover. Any other ideas?
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Nothing comes to mind, being it's brand new.
    bob...
  6. Hube
    Hube New Member
    Sep 1, 2004
    Ontario
    Are you sure the small tube/pipe that leads to the switch is clear of any crud/debris?
    This can effect the pump's contact points from opening/closing.
  7. pumped up
    Jul 15, 2005
    If small pipe to switch does have crud in it, how do I clean it out? Cut out electric to pump, disconnect, clean, reconnect and turn electric back on? Or do I have to open tap and reduce pressure in tank also?
  8. Hube
    Hube New Member
    Sep 1, 2004
    Ontario
    PROCEDURE:
    Shut power off to pump, drain tank, remove switch, clean pipe/tube.
    Also check the switch's contact points for smoothness (lightly use emery cloth to smooth).
Similar Threads: pressure switch
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch not providing true short Jan 12, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Is a pressure switch needed for this gravity fed system? Dec 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch nipple length?? Nov 11, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Do I have the wrong pressure switch? Sep 5, 2016
