I have an open geothermal loop in a 400' well with 120' of return line.
I also use this system for domestic water.
I have 2 pressure switches, one for the bladder tank, one for the geo loop. They are wired in parallel so either or both can call for pump.
There is a check valve on the bladder tank.
The problem I am having is with the geo loop pressure switch, on initial start the switch starts a 'rubber band' type of on then off.
When it's running the pressures run about 44 in and 32 out. It does not 'rubber band' most of the time... it normally starts smooth.
I have tried to remedy the issue by setting the press switch to a large differential of 10/60, but it still happens.
All piping is for 9gpm, the pump is 7gpm, with a very high static level.
It seems to me (I'm not a well/pump professional) that the initial surge is overwhelming the resistance of the geo valve on the return line and sending the pressure switch above high limit.
Was wondering if there are any 'slower acting' pressure switches available that might ignore an initial momentary surge?
Or maybe a way to absorb some of the surge, like a small expansion tank?
Every now and again (couple times a year) the system struggles to push the air out of the return line. My geo heat pump is several feet below my pitless. Not sure this has anything to do with my problem.. just figured I'd throw it out there in case it's a clue
The system was done piecemeal at my direction, so I'm the only one to blame.
I figured I should put that out there so it's not a distraction.
Your constructive feedback is welcome
Thanks in Advance
Andy
PS I'm going abroad in 2 days, so there might be a void in my response
Thanks in Advance
Andy
