Pressure Switch for booster pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Bob1000, Mar 16, 2007.
  1. Bob1000
    Bob1000 New Member
    Jan 10, 2007
    Egypt
    Right now I use a Square D pressure switch and I set it to 44 /67 psi
    The switch is new ( one month old ) but I think I am using its rates max limits ( 66.7 psi is its max pressure limit) because I did not know at the time of purchase that I would need that pressure setting
    The swich then jams often and keeps the pump running but it would kick out if I knock on a little knock
    I will buy anothe one of higher pressure rates but I wonder if there is any DIGITAL pressure switches in the market , I think they would be much easier in the setting and adjustement
    Any advice?
    Thanks very much in advance
  2. Bob1000
    Bob1000 New Member
    Jan 10, 2007
    Egypt
    Thank you very much , it is very interesting !
  4. Raucina
    Raucina New Member
    Jul 30, 2006
    toiletvalveguy
    Square d makes many versions of switches, some with fixed differentials that take guess work out of set up. Look at Graingers under well AND compressor pressure switches, there must be 30+ variations under 50 bucks.
Similar Threads: Pressure Switch
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch not providing true short Jan 12, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Is a pressure switch needed for this gravity fed system? Dec 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch nipple length?? Nov 11, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Do I have the wrong pressure switch? Sep 5, 2016
