Pressure Switch delays clicking on.
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by crazyweazle, Oct 16, 2013.
  1. crazyweazle
    crazyweazle New Member
    Oct 16, 2013
    Virginia
    Lately we've had problems with the water stopping if the washing machine is using both hot and cold water, of if you flush the toilet while running hot water in the bath tub. It sometimes will stop for a minute or more. I replaced the pressure switch and gauge, also made sure the air pressure in the bladder is 2 lbs below the cut on pressure. Even with the new pressure switch, it delays clicking on after the pressure drops below the cut on pressure. Once the pump cuts on, the pressure quickly rises and continues to rise 20 to 40 lbs above the cut off pressure, even tho the pump actually cuts off at the correct pressure. (I figure this is not uncommon tho.) I have a deep well submersion pump of unknown age, we have lived here for 15 yrs.
    Any advice would be greatly appreciated!
  2. VAWellDriller
    VAWellDriller Member
    Sep 8, 2012
    Mud rotary well driller, pump installer
    Richmond, VA
    The 1/4" pipe nipple leading to the pressure switch is likely clogged.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Try letting some air out. My guess is your air gauge is not reading the same as your water gauge resulting in too much precharge so that the bladder is bottoming out.
  5. crazyweazle
    Oct 16, 2013
    Virginia
    Will try cleaning out the 1/4" pipe to the switch, which I should have done when I replaced the pressure switch (but didn't.) I do know that the screen on the cold water line on the washing machine was almost clogged with grit and the problem actually started after I cleaned the screen.
    Thanks to both of you for your replies!
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Have you checked to see if the two gauges read the same?
Similar Threads: Pressure Switch
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch question Friday at 8:33 AM
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch not providing true short Jan 12, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Is a pressure switch needed for this gravity fed system? Dec 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch nipple length?? Nov 11, 2016
