Pressure switch and pump start relay
Discussion in 'Irrigation / Sprinkler Forum' started by cblanfrd1, Sep 25, 2008.
  1. cblanfrd1
    cblanfrd1 New Member
    Sep 25, 2008
    I installed a pump start relay for my watering system. I always had pressure switch problems. Now that I put the relay on I also need the pressure switch to operate my outside spigot. Is it possible to wire in the pressure switch to use my hose without something back feeding to my relay.
    Thanks
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    What you are doing makes no sense. Either use one or the other. If you have them wired in series, the pressure switch will still keep the pump off until the pressure gets to the cut in setting. With the timer only, you have no on demand water.
    bob...
  4. cblanfrd1
    Sep 25, 2008
    Found solution
    I had a electriction come over and he got it working the way I wanted it. I had to put a on/off switch to turn the pressure switch off/on when I wanted to use it. And my pump relay switch works when the timer comes on.
    Works gread
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    It still makes no sense to me. But if that's what makes you happy, who am I to argue?
    bob...
  6. cblanfrd1
    Sep 25, 2008
    pump relay
    The reason I want it this way is: When I was on vacation I had my pump running while I was gone. At some point the pressure switch would not cut off when it was suppose to. I adjusted it and it would work for sometime and it would act up again. So I put a pump start relay on. It worked perfect everytime because the power to the pump cut off at the proper time.
    But I had my hose hooked into the system too. But it would not come on because it wouldn't work through the pump start relay unless I put a valve inline to do so. But that ran all the time and needed it to turn off when I turned off my hose. So by using the pressure switch on the hose it worked. And if it didn't stop I was there to stop it. The only time the pressure switch will work is by a on/off switch to turn it off. It is not on whenever the valves come on. So the pressure switch will not interfere with the start relay. I sure like this setup.
    Hope understand how it works and the reason that I have it set this way. Took the electriction abit to know what I wanted. It kinda through him to but he got it to work the way I wanted it. Now I can leave and not have to worry about my watering system
Similar Threads: Pressure switch
Irrigation / Sprinkler Forum small pump in stream - pressure switch? Tank? Jul 29, 2011
Irrigation / Sprinkler Forum pressure system switch chatter Jul 4, 2011
Irrigation / Sprinkler Forum Flussmatic Marina vs Pressure tank and Pressure switch Dec 22, 2008
Irrigation / Sprinkler Forum System Design Decisions - Pressure Tank, Relay, Pressure Switch, Valve Placement??? May 14, 2008
Irrigation / Sprinkler Forum PUMP built in pressure shut off switch Jul 9, 2006
