pressure relief valve
Discussion in 'Irrigation / Sprinkler Forum' started by rbig, May 24, 2010.
  1. rbig
    rbig New Member
    Jan 28, 2008
    Florida
    I'm thinking of putting a pressure relief valve in my pump on top (where it goes into the water valves).
    I'f one of the valves ever gets stuck shut, pump damage can occur.
    1. what would a good pressure be (40lb? 50lb? whatever.....?)
    2. Where can I find an inexpensive one that will do the job?
  2. hj
    You are correct that a "locked" system could damage the pump, but an "inexpensive valve" may not be the solution. IF that were to occur your valve would have to be able to flow enough water to keep the pump volute from overheating. You also need a pressure setting that is lower than the pump's natural "cutoff" point, yet higher than the pressure when it is watering properly. Too high a setting and it would NEVER open regardless of what is happening with the valves, and too low and it will discharge while the watering is going on.
  4. rbig
    rbig New Member
    Jan 28, 2008
    Florida
    What's out there that will work?
Similar Threads: pressure relief
Irrigation / Sprinkler Forum Pressure relief valve questions Oct 2, 2007
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Wilkins 975xl Flow/Pressure Issues Oct 21, 2016
Irrigation / Sprinkler Forum Irrigation pressure regulator adjustment : lock nut is too tight Jul 9, 2016
Irrigation / Sprinkler Forum No pressure in line on one Zone May 31, 2016
