pressure releif valve
Discussion in 'Irrigation / Sprinkler Forum' started by fredw, Oct 4, 2005.
  1. fredw
    fredw New Member
    Oct 4, 2005
    safety consultant
    Agawam, MA
    I just had a inground sprinkler system installed and had a separate water meter installed. The first time I used it, my house water pressure dropped. After the second time, I had no water at all in the house. The house water has a pressure releif valve because the water pressure is 125 lbs. I had the town check the house meter to see if it was okay. It was but he also took apart the pressure releif valve, cleaned it and put it back and all was well. After I used the sprinkler again, the same thing happened. After the sprinkler shuts off, I can hear a bang in the pipes. What is wrong that makes the relief valve malfunction?
  2. hj
    valve
    Pressure relief valve or pressure regulating valve? The two do entirely different things, but neither should cause the symptoms you describe.
Similar Threads: pressure releif
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Wilkins 975xl Flow/Pressure Issues Oct 21, 2016
Irrigation / Sprinkler Forum Irrigation pressure regulator adjustment : lock nut is too tight Jul 9, 2016
Irrigation / Sprinkler Forum No pressure in line on one Zone May 31, 2016
Irrigation / Sprinkler Forum Well pump just bubbling, no pressure May 22, 2016
