Pressure Reducing Valve: Bad?
JohnnyO
Twin Cities, MN
Reading up on household water pressure, it seems the 90-95 showing on my PRV is too high.
I'm assuming the pressure shown as actually post-reduction, and not the street pressure, but I can't find any reference to this Wilkins Model 70 value that also shows the attached gauge, so I'm not positive.
This was new about 5-8 years ago.
Does this value need to be replaced, or should I try adjusting the valve via the screw, or is the pressure displayed actually the pressure BEFORE reduction?
Thanks,
John
I would try adjusting it first. You can also pick up a gauge at a hardware store that works with your outside hosebib to check pressure too.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Yeah that gauge should be reading donwstream or house pressure. Looks like the bolt is tightened down a bunch. Try loosening off on the adjustment bolt.
JohnnyO
Twin Cities, MN
I ordered and received the repair kit. With that in hand, I did get a second gauge and connected it to an outside hose bib to double check the pressure. They matched (within 3-4 PSI). I adjusted the knob out about 1/2 inch, ran some water, turned off the water, and noted no change in pressure.
Next step - do the repair kit. I think I'll wait to tomorrow for that.
I appreciate the advice!
John
JohnnyO
Twin Cities, MN
PRV repair completed! [It took one borrowed big wrench for the bell housing and one purchased 1 1/8" socket for the cartridge removal, but other than that, it went smoothly.] Thanks for the guidance!
Best of all - 6 hours after the repair, and no leaks!
John
