Pressure not building
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Tim in Miramichi, Oct 14, 2009.
  1. Tim in Miramichi
    Tim in Miramichi New Member
    Oct 14, 2009
    Miramichi, NB, Canada
    Hi all,
    I'm new to the forum and I have a problem that I am helping my uncle with at his place. I have a similar problem at my house (miles away, very different depths) and I'm hoping that helping him will let me solve my own problem.
    His pump will kick in and begin building pressure, but it will only build to 28 psi.
    He has set the switch to run at 20/40 for the time being, so what he is doing is running the water very sparsely. When the pump kicks in, he goes down and turns it off and back on again. This way, he is keeping the pump from burning out.
    He assumed it was a problem with the foot-valve, so we dug up the well head and pulled it out. We replaced the lines and the foot-valve and put everything back down and hooked it up. But, we are still having the same problem.
    Any ideas?
    Thanks in advance,
    Tim
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    is it a two line system with a jet in the well? If it is, the jet can get plugged with crap and cause your problem. Pull it up again, remove the jet and clean it out.
  4. Tim in Miramichi
    Oct 14, 2009
    It is a two line system as you guessed.
    There is a jet, and we ran a lot of water through it. To check that it was clean I placed the end of the jet that leads to the foot valve in a bucket of water and blew into one of the other ends that leads to the house. Water splashed back up at my face, so I took that to mean that it was pretty clean (my face...not so much).
    Any other ideas?
    Thanks,
    Tim
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Things that can cause that problem
    something in the jet
    Jet is worn out
    Suction line leak
    Pressure line leak (the on to the jet, smaller pipe)
    Worn out pump
    I'll still be on something in the jet. You really need to run something through the jet like a straight coat hanger
  6. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Peter Griffin's right!
    The nozzle in the jet assembly is plugged or partially plugged. You need to remove the jet assembly and remove the fittings from the larger inlet pipe on the assembly. Then remove the Venturi it's a long tube unually protuding out of the jet assembly (it's a right handed thread). take a 3/4" long socket and unscrew the nozzle deep in the jet assembly (it's a right handed thread as well). Then clean out the nozzle. It should have a 1/4" hole in it. Check the nozzle hole with a 1/4" drill bit. . . if it's a larger hole replace the nozzle or the whole jet assembly. Clean everything up good and replace everything being sure nothing plugs the nozzle again. Reinstall everything, prime the pump and you will have pressure again! Pumps don't build much pressure, they just move the water. The jet assembly builds the pressure.
    Porky, MGWC
    Master Ground Water Consultant
Similar Threads: Pressure building
Pumps and Tanks Well Forum & Blog. Water is life. Sta rite 1hp vertical deep well pumping but not building pressure. Jan 9, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Tank Outbuilding Aug 31, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump Running Not Building Pressure Above 20 Apr 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. New pump not building pressure Jun 16, 2015
Pumps and Tanks Well Forum & Blog. Water is life. No pressure building in tank Aug 17, 2012
