Pressure for watering system
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by fredflin, Mar 27, 2009.
  1. fredflin
    fredflin New Member
    Mar 27, 2009
    Hi
    I have a 4 channel watering system which until recently I was running of the municipality water with no problems. We've recently gone ahead and had a Well Point installed (about 12 meters deep pump above ground type). The well point pump unfortunatly doesn't have enough pressure to drive the watering system. I also have a 500litre tank.
    I assume to fix the pressure problem I am going to have to either pump the water into the 500litre tank and then use another stronger pump for the watering system or I have heard of pressure tanks but am not understand how these work.
    Please can someone help me so that I can use the well water in the irrigation system.
    Thanks very much
    Newbie
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Pressure tanks don't make pressure, pumps make pressure. If you tell us what kind of pump you have, we can tell you how much water and pressure it will build. If you try to use more water than the pump can supply, you won't have any pressure. You are also limited by how much water the well will make. You can't pump 12 GPM if the well will only make 10 GPM. You have to match how much water the well will produce, with a pump that will provide the correct amount of water, at the pressure you need. Then you have to match the amount of water being used, with the amount and pressure the pump can supply.
  4. fredflin
    fredflin New Member
    Mar 27, 2009
    aaaaahhhh I understand. What informain ae you looking for from the pump? i know it is a 1hp pump... I have an old pool pump which I could use but I suspect that will be tooo much.....? I'll take a look at the pump for some more details.
    Thanks
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    Horse power is a good start. Make and model would be next. And you are talking litres and meters, so is this a 50 hertz motor?
  6. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Pool pumps make terrible sprinkler pumps.
    bob...
Similar Threads: Pressure watering
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure fluctuates Yesterday at 7:40 AM
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Saturday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Well head pressure relief valve Feb 6, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Want to change well tank pressure Jan 27, 2017
