Pressure flush toilet leaks at floor
Discussion in 'Toilet Forum discussions' started by MrTelco1948, Sep 13, 2012.
  1. MrTelco1948
    MrTelco1948 New Member
    Jul 9, 2010
    Severn, Md.
    Hello everybody. I have a pressure assisted toilet that routinely blows out part of the wax ring, causing seepage under the toilet. I have replaced the ring numerous times and the last time, I used a reinforced wax ring but still have the problem. (Early on, I had to make a slight adjustment and raise the flange to the proper height so the bottom of the flange was even with the floor. Thought that was the problem but it didn't help.) Any thoughts would be most appreciated.
  2. jadnashua
    If there's a partial blockage in the drain line, that might cause it. There's one closed cell foam wax ring replacement product some people here have used and should be more robust in that regard.
    But, the biggest candidate is that the toilet may need shims to keep it from rocking...the wax isn't springy, and once you set the toilet, any rocking will cause the wax to compress, and when it rocks back, leave a gap. It doesn't take much. Set the toilet in place without wax, and if it can move at all, figure out where to place shims to stop it, then add the wax, and set it on the shims. If the floor is pretty close and the toilet isn't badly warped, I find that an assortment of coins, penny, nickel, or dime, is all it usually takes to solidify things. You can make a trip to the store and buy some composite shims, and those may be needed if the gap is bigger than an astutely placed coin or two will resolve.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Is this pressure assist toilet one that is on the recall notice? If it is, you'd be wise to quit using this thing and either get the replacement parts or get rid of the PA toilet altogether and get a Toto that does not require pressure assist with the explosive noise and potential explosion problem. There are better toilets available.
Similar Threads: Pressure flush
Toilet Forum discussions Gerber Ultra-flush not working well since pressure regulator added Mar 26, 2016
Toilet Forum discussions Flushmate Recall on Flushmate® III Pressure-Assisted Flushing System for Toilets Jun 25, 2012
Toilet Forum discussions Kohler K-3493 Highline Pressure assist 1.4gpf - Weak flush Aug 11, 2011
Toilet Forum discussions Pressure Assist First Flush of the Day Jul 15, 2011
Toilet Forum discussions Gerber pressure flush questions Oct 14, 2010
