kadidlehopper
HERE IS WHAT I HAVE
CREEK PUMP SYSTEM used for irrigation only
Wayne 3/4hp convertible pump (CWS75) set up for deep well use.
Parts20 flotec jet assembly (FP4800) using #52 jet and #24 venturi
20gal Water Worker tank (HT20HB) set at 27psi
1-1/4" suction poly pipe
1" drive poly pipe
50' from water source (creek), 30 of which is up hill
The pressure switch is set for 30-50
I also have a well pump system that is interconnected to the creek pump system which allows me to open a valve and use it to prime or increase the psi for testing purposes of the creek pump system.
The creek pump system will not pressurize above 30psi and so will not shut off the pump. When I turn off the pump the pressure instanly drops to 20psi and will hold that pressure unless I open a faucit. When I turn the pump back on it quickly builds back up to 30psi but no higher. I can close the valve between the tank and the pump and still get the same results. The pump, tank, and jet assembly are new so I don't think they have a problem. If I use the well pump valve to pressureize the creek pump system to 50psi the pump turns off and holds the pressure. However when I open a faucet the pressure sloowly drops to 30psi and the pump starts but will not pump the system past 30psi. I have checked the system for leaks and have none. If I drain all the water out of the lines then reprime the pump the system will again pump up to 30psi and no higher, pump just keeps running, and again when I turn off the creek pump the pressure drops to 20psi. I cannot understand why the psi drops instantly to 20psi when the pump is shut off, or why it will not pump past 30psi. My pressure guage is sitting on a tee about 3" above the rest of the feed line to the tank, could that be holding air and causing the pressure to drop when the pump shuts off.
I am thinking about changing the jet and venturi but am not sure which ones to change them to. I have jets #51, 52, and 53, and venturis #18 and #24. Also because of my age (over 70) I find it very scarry to go down the embankment to the creek for the change so I am hoping someone might have another solution of suggestion. I cannot afford to call someone to fix it due to limited income and I lost my son about a year ago so I have no one else to help.
I also thought that perhaps the jet assembly kit I purchased might be the wrong one. Perhaps I should have ordered the one made by Wayne, the people that made the pump, but it was much more expensive.
I am at a loss for what to do next so I can get the system working correctly. Any help or suggestions would be welcomed.
kadidlehopper
1" drive poly pipe
kadidlehopper
