Pressure drop due to temperature change?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by North Jersey, Jun 6, 2009.
  1. North Jersey
    North Jersey New Member
    Jan 1, 2009
    What is the magnitude of the pressure drop in a gas line that can be attributed to temperature change? I pressurized the line with air for a leak test. The pressure dropped from 17.5 psi to 17 psi over about three hours. I noticed the temperature of the attic, where about 2/3 of the line runs, dropped around 15 degrees during this time. If you're doing a 24 hour test, what kind of pressure change could be chalked up to temperature?
  2. jimbo
    jimbo Plumber
  4. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    nano plumbing
    And in laymens terms...¿
  5. jimbo
    jimbo Plumber
    P1 is your starting pressure. Multiply it by the ratio of the new temperature divivided by the original temp. to get the new pressure P2..
    I have to double check what units the temp. must be stated in. It might need to be kelvin.
    edit: yes, temp. is in ºK. So, lets take an example:
    starting Temp. 80º Ending temp 65º
    starting press. 15
    ending pressure = 15 X ( 291.98/299.81)
    ending pressure appro. 14.6 PSI
    note: I hope PSIG is the proper unit for pressure. Might it have to be PSIA?? I have to sort that one out!
  6. hj
    pressure
    One the temperature stabilizes, the pressure should also. That is why the inspector usually only checks it during a 15 minute period, assuming you have a very delicate gauge.
  7. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    I use a manometer to test gas lines. It is by far the best method. I use a mercury manometer to test rough piping (as per UPC) and water manometer to test final. It let's you know instantly if you have any leaks.
  8. North Jersey
    Jan 1, 2009
    I kept the line under pressure over weekend. After it bottomed out, it rose half a PSI by Monday morning, so I feel pretty confident I'll pass my inspection.
    I should have thought of using the manometer I bought for my HVAC projects. I was just using a 25 psi gauge with .5 psi increments, which is what the propane company and the inspector will look at.
  9. hj
    gauge
    Here, it has to be a 10 psi test using a 15 pound gauge with 1/10 psi graduations. Even a manometer will respond to the pressure variation from temperature changes.
Similar Threads: Pressure drop
Plumbing Forum, Professional & DIY Advice Main Water Feed - 20psi Pressure Drop When one Fixture is Open Dec 23, 2016
Plumbing Forum, Professional & DIY Advice Drop in water pressure after new softener put in Nov 3, 2016
Plumbing Forum, Professional & DIY Advice How to eliminate pressure drop? Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Instant pressure drop [like slamming a door]. Jun 12, 2015
Plumbing Forum, Professional & DIY Advice Least pressure drop check valve type? Nov 26, 2013
