Pressure difference between Bleed Valve vs Solenoid
Discussion in 'Irrigation / Sprinkler Forum' started by mattofatto, Jul 22, 2009.
  1. mattofatto
    mattofatto New Member
    Jul 22, 2009
    Hello,
    I set up my sprinklers so that I can run 3 rainbirds on one of my stations. It runs great when I turn the manual bleed valve. But, if I run the automatic sprinkler/solenoid valve, then I only have enough pressure to run 2 rainbirds... and they seem to be a little low pressure. What's the deal? Why do I get so much lower pressure on the automatic system?
    They are new solenoids, new controller... but they are manual to automatic conversions.
    Any ideas?
  2. BRD
    BRD New Member
    Jun 22, 2009
    irrigation contractor
    northeast
    Based on the fact that you say the valve opens fully when you manually open the valve, it appears to me that for some reason the solinoid plunger may not be coming up all the way when it is electrically actuated to allow the water to exit the upper chamber at the proper rate. I'm not sure what you did to convert your valves as you say. Do you have the correct solinoid? and if you have other zones do they operate properly? Maybe you just have a stuck solinoid. Try another one, or switch with another valve.
  4. tomm
    tomm New Member
    Feb 21, 2008
    The clock can only operate so many solenoids at once. More than likely you are exceeding the output capability of the transformer.
  5. mattofatto
    Jul 22, 2009
    Thanks for the responses. Here's a little more information.
    I'm only operating one station at a time, but I have 2-3 rainbirds per station.
    I was having the problem from the first day I moved into the property. I thought it was a bad solenoid, so I swapped that out.. no change. I thought it might be the controller, so I swapped that out. That fixed another problem, but not this one. I thought maybe there was something wrong with the cheap valve that was previously on that station, so I bought a nice brass one:
    http://valuesetters.com/vendor_20_product_images/57034.jpg
    Same problem.
    Here's what the whole valve looks like:
    http://www.amazon.com/dp/B000FBQJK4...3E84IP&tag=shopzilla_rev_1218-20&linkCode=asn
    The lower part was here previously, and I've swapped everything else out except the wiring.
  6. upper
    upper DIY Senior Member
    May 30, 2009
    Fresno, CA
    Have you taken the WHOLE old valve out and replaced with all NEW? Upper
  7. mattofatto
    Jul 22, 2009
    I replaced everything in the first picture.
Similar Threads: Pressure difference
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Wilkins 975xl Flow/Pressure Issues Oct 21, 2016
Irrigation / Sprinkler Forum Irrigation pressure regulator adjustment : lock nut is too tight Jul 9, 2016
Irrigation / Sprinkler Forum No pressure in line on one Zone May 31, 2016
Irrigation / Sprinkler Forum Well pump just bubbling, no pressure May 22, 2016
