Pressure Balancing Valve
Discussion in 'Shower & Bathtub Forum & Blog' started by ceiiinosssttuu, May 2, 2013.
  1. ceiiinosssttuu
    ceiiinosssttuu New Member
    Apr 23, 2013
    Idaho
    Building a new master shower with antique-looking exposed copper plumbing
    Hi, I am building my own house and roughing in my master shower. I want dual shower heads with an antique, industrial look with exposed copper shower plumbing (see diagram). Initially I ran 1/2" pex, but I was told I would need more volume for a dual shower, so I ran another set of 1/2" pex (it was easier than running 3/4 since I already had a 3/4"-to-1/2" manifold). So now I have two 1/2" pex hot lines and two 1/2" pex cold lines that I need to connect back together with a pressure balancing valve (per code). Would either of the ideas in the diagram work? Which is better? Is there a better idea I'm not thinking of?
Similar Threads: Pressure Balancing
Shower & Bathtub Forum & Blog Pressure balancing manifold for shower head and handheld sprayer out of CPVC? May 9, 2013
Shower & Bathtub Forum & Blog Use a pressure balancing valve and ball valves for shower controls Apr 23, 2013
Shower & Bathtub Forum & Blog Grohe Pressure Balancing Rough-In Valve Feb 20, 2011
Shower & Bathtub Forum & Blog pressure balancing loop for 4 sprays Oct 11, 2010
Shower & Bathtub Forum & Blog Pressure-balancing Moen shower-tub valve releasing hot water in the "cold" position Oct 1, 2010
