Pressure Balance Valve is Stuck!!!
Discussion in 'Shower & Bathtub Forum & Blog' started by nediver, Dec 26, 2007.
  1. nediver
    nediver New Member
    Dec 26, 2007
    I have a one knob shower control. I think its an older Delta, bout 25 years. Anyway, I wasnt getting any cold water so I replaced the cartridge. I think the problem is the pressure balance valve. It is stuck. I tried everything from a flat head to vise grips. Tried using break lubricant and everything. What do you all suggest?
    -AD
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Did you get a new one? Cartrage.maybey replace it.
  4. jadnashua
    I didn't think they were using pressure balanced valves 25-years ago...think you may have some crud buildup in the cold supply side.
  5. hj
    spool
    Delta doesn't give you a lot to grab with that spool. When I encounter one like you indicate your is, I use a hammer and a small chisel and tap it in the unloosening direction. Once you move it even a small amount, then the screwriver or Crescent wrench will finish the job of removing it.
Similar Threads: Pressure Balance
Shower & Bathtub Forum & Blog Best type of shower mixing valve / highrise bldg with poor pressure balance Dec 21, 2016
Shower & Bathtub Forum & Blog Grohe 35015000 Universal Pressure Balance Rough-In valve Feb 10, 2015
Shower & Bathtub Forum & Blog Riobel pressure balance Shower Valve May 30, 2014
Shower & Bathtub Forum & Blog re: the most reliable shower pressure balancer system. Nov 4, 2013
Shower & Bathtub Forum & Blog Pressure Balancer problem May 28, 2013
