prep to paint cement floor.
Discussion in 'Remodel Forum & Blog' started by cmw, Feb 6, 2006.
  1. cmw
    cmw New Member
    Mar 23, 2005
    New York
    I currently have a below grade vinyl tile covered floor (20'X20'). The tiles are removed & I am left with tile adhesive on the floor. I would like to avoid removing the adhesive and just paint over the adhesive. Not trying to get perfect results. Is there a paint/primer system that will bond with the adhesive and not peel off?
  2. Duane Smith
    Duane Smith New Member
    Jan 27, 2006
    Muratic acid will take care of it. Little caustic want to wear rubber gloves. There are other items that will remove it. Check with a few flooring guys.
  4. prashster
    prashster New Member
    Dec 7, 2005
    The floor will be ok as long as you don't put anything point-heavy on it - like a table saw. I painted my floor and it tends to peel up at points of heavy load.
    If you really want to do it right, you have to power wash it, etch with muriatic acid, and paint it with an epoxy paint. But if you can tolerate a little peel or don't mind touching up every couple years, it's a whole lot easier to use normal porch and floor primer & paint.
  5. Mike50
    Mike50 DIY Senior Member
    Jan 8, 2006
    Southern California
    FWIW Kemiko concrete stain carries a Rembrandt line of polymer paints/stain which will give you many choices for a custom colour not available at the local big box store. Scofield probably does to.
    http://www.kemiko.com/rembrandt.htm#
  6. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    go to sherman willinam
    dont waste your time at LOWES looking at
    cheap basement floor paint
    go to SHERMAN WILLIAMS if you have one in your area
    they have some MEAN epoxy paints that you can sprinkle those
    flakes into to hide the inperfections in the floor
    they also have some pretty mean commercial grades of concrete paints
    that you simply wont find anywhere else...which you can have shaded to whatever color you choose
  7. Snowman
    Snowman New Member
    Mar 17, 2005
    Retired math teacher
    FLORIDA
    I just cleaned my floor with some TSP, rinsed and painted with Floor and Porch waterbase latex. Used 1/4" making tape to make the lines. Finished off with a waterbase sealer designed for painted concrete.
  8. Mike50
    Jan 8, 2006
    Southern California
    dood that's..
    Sweeeet! :D
  9. Snowman
    Snowman New Member
    Mar 17, 2005
    FLORIDA
    Well, Cookie all I need is some encouragement from a nice good looking young lady .... (thanks to you too Mike) :)
    So here's my back porch..... same process....
  10. Snowman
    Snowman New Member
    Mar 17, 2005
    FLORIDA
    For some reason I have to make another post for the next picture..... Anyway..... I used a base coat of "Off White" and again used 1/4" masking tape for the grout lines....
  11. Snowman
    Snowman New Member
    Mar 17, 2005
    FLORIDA
    Finally, made some faux tile paint using :
    1. Latex floor and porch (three different colors)
    2. Dilute with a little water
    3. Added latex paint conditioner
    I then used an old 4 inch paint brush to stipple the finish..... Used brownish red, gold and black colors then stippled them together... Oh yea, I sealed everything with a clear coat made expecially for painted concrete... Same stuff I used in the study.
  12. sulconst2
    sulconst2 New Member
    Jul 11, 2005
    remodeler
    old bridge nj
    snowman showing some range!! very nice work!!
  13. Terry
    Aug 17, 2004
    That is way cool.
    I don't understand about the masking tape though.
    Do you just leave it on for one coat? And then peel it off?
    That could look good for my garage floor.
  14. Mike50
    Jan 8, 2006
    Southern California
    I agree..and have the same question as Terry.
    You manged to get a leathery 15 year old look Snowman and that
    requires artistic talent to produce a product like that.
    This an example of why people are seriously looking at the whole concept of decorative concrete as an indoor option also.
    Truthfully, I have never cared for the faux tile look-just a personal preference.
    But this is a lot better than good-it's a knockout. kudos...
    Mike
  15. Snowman
    Snowman New Member
    Mar 17, 2005
    FLORIDA
    Thanks to both of you. :p Warning: Details to follow, sorry I can't do this in 20 words or less ;) OK, the tape was a very difficult thing to deal with when we got started. Had to look around a bit to find 1/4" masking tape. The way the process was "supposed" to work is this:
    1st you clean the surface the best way you can . TSP or Mur. Acid , and/or both. Of course one after the other. I took a chance and just used TSP. A year later it is still doing fine.
    2nd. You would normally put down a base coat of an off white floor and porch latex and allow that to dry for several days.... Did that too...
    3rd. It is not difficult using a t-square and then a chalk line to lay out your squares. Followed by putting down the 1/4" tape. Our first project was the back porch.
    4th Create your faux tile look with several colors of very very "watery" faux paint that you make yourself. Then, when that is dry, you pull up the tape and you have your off white faux grout lines which you can paint with an artist's brush , if you want.
    That's where things didn't go as planned or as predicted. You can probably guess what happened. Even though we gave the base coat extra time to dry, as I pulled up the tape, it started pulling up the base coat with it. That might have been OK, but it did not pull up the base coat evenly. It was going to become a mess. So, I stood back looked at the tape, which looked like real grout lines and said to myself, "what's the worst thing that can happen if I leave the tape down?" So I left it down. :eek:
    5th After I gave everything plenty of time to dry, I covered the whole thing with this: BEHR WET-LOOK SEALER is a clear, non-yellowing, high solids, acrylic-based masonry sealer. It is formulated to seal, protect and beautify concrete and masonry surfaces with a hi-gloss, wet-look finish. BEHR NO. 985 WET-LOOK SEALER is also an excellent topcoat for paints and stains. Plus it is a water base sealer.... Nice and easy too.
    I happened to talk with the Behr Paint Factory Rep here at the local Home Depot a few weeks later and told him what I had done. His reply was: " what?? and you expect that to keep the tape down? As soon as the adhesive dries out, that tape is coming up." He might be right, and if it does, I'll just paint in the grout lines... Well, it has been a year now and I've put on 3 coats of the sealer, each coat makes it look even better. The tape have not come up at all, anywhere. even at places where the patio furniture has been drug across it. Also, my back porch is covered. That might be one reason it has done fine. In my next post I'll tell you how we did the study (red floor) and we were able to get the tape up without pulling up the base coat. We did it a bit different.... after what we learned.
    Wow, this has become L O N G. Sorry 'bout that. :rolleyes:
    See ya, Tom
  16. motherbeardancing
    motherbeardancing New Member
    Aug 13, 2009
    prepping concrete floor to paint
    Dear Snowman,
    Your floor looks gorgeous. Can you tell me what brand paint and color you used in your den? Also, my concrete floor was just recently poured, so it's still curing. It hasn't been sealed. Should I seal it before I paint it? Or just paint the raw concrete? I love your results. Is your floor holding up well three years later?
    Thanks very much, motherbear
  17. Cookie
    Cookie .
    Oct 7, 2005
    We haven't heard from Snowman, Tom, in a long time, I tried emailing him several times. In the beginning of this thread it tells about using Muriatic Acid first and some other tips. I really would not paint raw concrete, (without preparation) I doubt it would stick. And, yes! his floors are beautiful.
  18. motherbeardancing
    Aug 13, 2009
    Cookie,
    Thanks for the tip, and sorry to hear that Snowman's not posting any more. I've had a couple of contractors say to use this two-part epoxy process, but I was so impressed with Snowman's results with water-based latex. He makes it look easy.
  19. hj
    tile
    I painted my patio to simulate flagstone rather than tile. But the process is the same. A base coat in the grout color, masking tape to make the joints, and then the tile, (or flagstone colors in my case), applied over it. I apply a clear satin finish sealer over it every couple of years.
  20. Cookie
    Cookie .
    Oct 7, 2005
    He is a Principal of a high school the kids probably drove him crazy! I can't say I don't understand it. You can do the floor, make sure you post a picture when all finished, and let us know how you did it.
  21. Alton.cedric
    Alton.cedric Guest
    I know someone did that and it like to never dryed plus with moisture a basement has you have to get the right paint i would suggest asking someone at Lowes or home depot or a well trained painter. it can be a headache really.
Similar Threads: prep paint
Remodel Forum & Blog Basement Finish Prep Work Mar 12, 2017
Remodel Forum & Blog Earthquake Retrofit Prep Work Dec 9, 2012
Remodel Forum & Blog prepare for the tile basement bathroom Dec 1, 2012
Remodel Forum & Blog How to prep a laundry room floor with floor drain for tiling? Aug 28, 2010
Remodel Forum & Blog sub floor prep for laminate Sep 25, 2008
