Premiere Walk-In Tub Drain
Discussion in 'Shower & Bathtub Forum & Blog' started by tchp, Nov 10, 2009.
  1. tchp
    tchp New Member
    Jan 10, 2007
    I have a Premier step-in safety tub that needs a replacement drain fitting, and it is an atypical fitting type (possibly European, as the tub is made in the UK), and I have not been able to find a replacement. I have attached an image. I have the black plastic flange for the overflow drain, but there is a similar flange for the main drain that I also need. It is not like U.S. style drains in that it is just a single screw that tightens the chrome flange inside the tub against the plastic flange on the outside, in order to make the connection water-tight. I was hoping someone might recognize the manufacturer and know of a supplier. I have been told that it is very hard to get parts direct from Premier itself.
Similar Threads: Premiere Walk-In
Shower & Bathtub Forum & Blog Installing a walk-in tub Apr 16, 2016
Shower & Bathtub Forum & Blog Drain and faucet position for walk-in shower Oct 23, 2013
Shower & Bathtub Forum & Blog Walk-in bathtub reversed drain Nov 27, 2011
Shower & Bathtub Forum & Blog WEDI walk-in shower base construction Apr 3, 2011
Shower & Bathtub Forum & Blog Walk-in Bathtub Recommendations??? Aug 10, 2009
