Premature lamp burnout
Discussion in 'Electrical Forum discussion & Blog' started by chitownsparkie, Jan 16, 2010.
  1. chitownsparkie
    chitownsparkie New Member
    Jan 16, 2010
    Chicago
    Several people have complained to me about lamps burning out after just a few days in recessed lights. I always ask them if they are using the reccomended wattage lamp for the fixture/ trim combo & if this is a re-occuring problem. This seems to be anot to uncommon problem , any thuoghts?:confused:
  2. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Several people where ?
    Houses...Apts....buying bulbs in a store ?
    Same type of bulbs...recessed fixtures...?
    CFL's...incandescents....other ?
  4. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    Poor quality bulbs. Return them for a refund!
    When I was a kid, light bulbs used to last a long time. About the last 10 years they have been getting worse and worse. Corporate greed if you ask me.
  5. Giles
    Giles Retired tool & Die and Mechanic
    Aug 28, 2007
    Retired
    N.W. Alabama--Florence--
    I think this has a lot to do with the power source (ocassional electrical spikes) and the home wiring.
    When I bought a rural home, there were many electrical problem. Bad or sloppy electrical connections that were often exposed and not in a junction box. It took me several weeks to correct the problems and during this time, I blew many light bulbs. I might add that several of these blown bulbs were in recessed fixtures that were covered with insulation. I replaced all the recessed fixtures with celing fans and other type fixtures.
    After correcting all the problems I could find, I blew about four regular light bulbs in a year.
    I have no other explination.
  6. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Assuming a bulb is on 4 hrs/day for 90 days gives a 360 hr avg. life for the sample size of four bulbs.
    What rated life was marked on their package? If it was 1000 hrs, and 120v bulbs, the voltage to your house over the 90 days should have averaged
    x = 120{[360/1000]^[-(1/14)]}
    =129v.
    Some people use 12 or 16 for the 14 exponent.
    In MD they are not allowed to go over 126v but some areas allow 132v.
  7. codeone
    codeone Code Enforcement
    Sep 5, 2008
    Code Enforcement, Instructor
    North Carolina
    Take the recessed can down and check the junctions in the j-box, espically the neutral connections. If you have one that is not made up properly they have been known to blow bulbs with spikes.
  8. wallygater
    wallygater New Member
    Dec 16, 2007
    long island
    Very simple solution
    I had the same problem with my bulbs blowing out after only a few days, some times after only a few hours. Try a very thin coating of Vaseline/ or conductive lubricant, on the threads. It will solve the problem. My bulbs in the problem fixtures now last years instead of hours. Sounds to simple, but it worked for me.
Similar Threads: Premature lamp
Electrical Forum discussion & Blog Halogen lamps inquiry Apr 21, 2016
Electrical Forum discussion & Blog Lamp in Middle of Room (Need Power Supply) Apr 19, 2012
Electrical Forum discussion & Blog GFCI, Dimmer Switch, Outdoor Lamp Posts with Receptacles Mar 27, 2012
Electrical Forum discussion & Blog Lamp Post Bulb keeps blowing out Aug 30, 2011
Electrical Forum discussion & Blog life of a metal arc lamp Aug 16, 2011
