Pre plumb water loop
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Talisker, Feb 27, 2013.
  1. Talisker
    Talisker New Member
    Feb 17, 2013
    Texas
    I don't have much knowledge on plumbing, but if someone can help with my question regarding pre plumb.
    House under construction, we got water softner loop in the garage. If I have water softner loop in the garage, do i need to get pre plumb refrigerator water loop in the kitchen? At this time we are not getting reverse osmosis. I don't what other information is needed for someone to help me with this question.
    Thx.
  2. hj
    What is a "refrigerator water loop"? If anyone is on a low salt diet, you WILL want an R/O system. I got mine because I do not like the "flat taste" of softened water. If you have a "water softener loop", then you also want to be sure that all the outside hose faucets connect BEFORE the loop so they do not use soft water.
Similar Threads: plumb water
Plumbing Forum, Professional & DIY Advice Clear water began turning brown after plumber's work Jul 8, 2016
Plumbing Forum, Professional & DIY Advice Rough plumbing layout w/ backwater check valve. May 21, 2016
Plumbing Forum, Professional & DIY Advice Plumbers STUMPED!! Sprinklers causing Airlock in Hot Water tank Apr 22, 2016
Plumbing Forum, Professional & DIY Advice Plumbing code for fridge water line cutoff Nov 19, 2015
Plumbing Forum, Professional & DIY Advice Shower - Plumbing Moen 3/4 valves with 1/2 inch water supply Aug 23, 2015
