Hello,
I have a question about the operation of a pre-charged water pump tank that is used in a house that has water provided from a well. If you have a pump tank lets say of 36 gallons and have the pressure limit cut on/off switch set at 40/60psi you will get about 9-9.5 gal. drawdown before it kicks the well pump on. So, if you replace the tank with a much bigger tank, say 80 gallons, using the same settings 40/60, you will get more water out before it has the well pump kick on again. But since more water comes out before the pressure builds up again, does this mean that you will have less water pressure for a longer time than if you would with the smaller capacity tank. In practical application, would the pressure of the water in the shower be less for a longer time than if one was using a smaller tank ?????? Is my thinking on track or am I missing some scientific principle that applies?
Drainplug
Drainplug
