powering sprinklers from hose
Discussion in 'Irrigation / Sprinkler Forum' started by tomshorse, Jul 14, 2005.
  1. tomshorse
    tomshorse New Member
    Jul 14, 2005
    is there a problem with going from a hose to pvc to sprinklers (hunter pro series 4" pop-up)? one (underground, all pvc) zone can power 7 heads like this but will going from a hose fitting to pvc deminish the psi or gpm normally?
  2. captwally
    captwally New Member
    Apr 30, 2005
    Apartment Complex Maintenance, Professional Chef
    Florida
    Absolutely! I don't have any of my pressure loss charts handy right now, but you will find that the psi loss per foot on standard garden hose is pretty scary compared to PVC pipe. Your best bet is to run PVC directly to the zone. It's inexpensive and worth it.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    First, the hose bibb may only be on a 1/2" pipe, so it does not have the same flow capability as a 3/4" line right off the main.
    Second, the loss in the hose will be significant.
    Third, where is the backflow prevention in this picture?
  5. hj
    hose
    The length of the hose, it probably being coiled up, and its inside diameter, will all combine to reduce the pressure and volume. You might not be able to operate more than a coupld of heads on any one zone doing it this way. In addition, if you are using a hose, it will probably, (and hopefully), be connected to a faucet with an external vacuum breaker, which will further diminish the possible volume.
Similar Threads: powering sprinklers
Irrigation / Sprinkler Forum Sprinklers worked, now not at all. For no apparent reason. Mar 11, 2017
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Feb 19, 2017
Irrigation / Sprinkler Forum Low Pressure Issue - sprinklers/well May 7, 2016
Irrigation / Sprinkler Forum Motion Beam for Sprinklers Apr 24, 2016
Irrigation / Sprinkler Forum Leaking sprinklers when system is off Feb 19, 2014
