Powerflex direct vent wont stay lit
Discussion in 'Water Heater Forum, Tanks' started by cannedham1, Aug 23, 2013.
  1. cannedham1
    cannedham1 New Member
    Aug 23, 2013
    NY
    Hi all, I have a 4 year old powerflex direct vent water heater that wont stay lit. All the lights blink on the gas control valve and there is a continuous clicking from it. The only way to get it to light is to blow in the black tube on the blower connected to the diaphragm and then I hear the diaphragm click and it lights. I thought the diaphragm was the problem so I changed that. I need help please.
  2. jadnashua
    By blowing through the black tube, you proved that the diaphragm switch was GOOD, not bad. It's doing its job as a safety interlock. There's a problem either with the fan, or exhaust venting - it's not moving the air properly, and creating enough pressure/vacuum to close the switch to keep it running. Could be a bird's nest, mouse, a separation in the exhaust venting, inoperative fan, crack in the tubing, etc.
  4. cannedham1
    Aug 23, 2013
    NY
    Thank you jadnashua. I read the manual and it says that the error code for all the lights being lit it is the gas control valve. Im going to make sure there isnt anything obstructing the vent.
  5. jadnashua
    The gas valve and the diaphragm switch are related, but not the same. That switch is in the interlock, safety circuit, and must be closed for things to work. Now, if it does close, and the gas valve doesn't open or the igniter fails to operate, that's a different issue. Could also be a flame sensor.
Similar Threads: Powerflex direct
Water Heater Forum, Tanks What else could it be: indirect hot water heater leaking? Aug 17, 2016
Water Heater Forum, Tanks Direct vented vs power vented water heaters Jun 8, 2016
Water Heater Forum, Tanks High Efficiency Water Heater vs Boiler with Indirect Feb 11, 2016
Water Heater Forum, Tanks Add Heat Pump to boiler heated indirect Jan 24, 2016
Water Heater Forum, Tanks Would like recommendations for indirect replacement Oct 26, 2015
