Power Rating
Discussion in 'Electrical Forum discussion & Blog' started by denverboz, Mar 4, 2011.
  1. denverboz
    denverboz New Member
    Mar 4, 2011
    Denver, CO
    OK at the risk of sounding like a dummass, I gotta ask what power rating means, as in
    power rating 120V 60 Hz 1281W, which are the specs for a Toto Neorest toilet.
    From what I can gather it doesn't seem to mean it uses 1281W, but I been wrong before. :)
    However if I am right is there any way to deduce just how much power it does use just from the power rating?
    TIA for any help .
  2. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    It means you need to supply it with a minimum 15 amp circuit.
  4. denverboz
    Mar 4, 2011
    Denver, CO
    so you mean it's own dedicated circuit?
  5. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    I answered in the other post but yes, a dedicated 15 ampere circuit would be the best.
  6. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    If it says 1281 watts then yes, it certainly does mean it uses, or can use, 1281 watts.
    Why would you think differently?
    No way. Not just from the ratings shown. If it uses a certian amount of power that's that. Unless of course there are settings on the unit that can vary the power, but that still does not change the fact that it CAN draw that much at any given time.
    May I ask why this is an issue?
  7. Speedy Petey
    Jun 16, 2007
    NY State, USA
    I also agree that a dedicated GFI protected circuit is required.
  8. jadnashua
    That is the maximum it could use...in 'standby' mode, it probably uses much less. To heat the water (and maybe the seat) quickly, it needs to draw some serious power. It probably does this 'on-the-fly', rather than keeping a quantity of water hot all the time. As to the seat, not sure...
Similar Threads: Power Rating
Electrical Forum discussion & Blog Power feed problems Feb 20, 2017
Electrical Forum discussion & Blog New Outlets= Erratic Dimming Power Jan 10, 2017
Electrical Forum discussion & Blog Another question: generator power necessary for 1/2 hp pump jet pump Oct 8, 2016
Electrical Forum discussion & Blog GFCI tripping with no load when connected to power Oct 7, 2016
Electrical Forum discussion & Blog Lost one leg of power need help. Aug 4, 2016
