Hi -
I have a Toto Power Gravity, which was installed new 5 years ago. In the last couple of weeks, after a flush, the fill tube continues spraying out water in the overflow tube, even after the bowl is filled. I find that if I gently push the fill valve toward the overflow tube, the valve activates and the water shuts off. What would you think the problem is? If it needs to be cleaned or a gasket replaced, could you explain the procedure?
Thank you,
Neal
Thank you,
Neal
