power generation
Discussion in 'Electrical Forum discussion & Blog' started by molo, Jul 17, 2007.
  1. molo
    molo Member
    Sep 23, 2006
    Cold New York
    "With a windmill coupled to a small electric generator [a rural inhabitant] could bottle up enough current to give him light at night." (Atlanta Constitution article, 1901.)
    Does anyone know if wind power is becoming affordable for residential power production? Does anyone have experience to say it is a good or bad idea?
    Molo
  2. Cass
    Cass Plumber
    Nov 12, 2005
    You need to have fairly steady wind and for a certin number of hours a day to make it worth while.
    If ti is a viable thing I would think there would B people in the area doing it, you should be able to research it on line and find you answer.
    Wind generators doent even start producing electricity until the wind is at 8 MPH and reaches peak output at 27 MPH.
  4. jimbo
    jimbo Plumber
    I am sure a google could find you lots of info on generators. The larger expense will be the batteries and inverter. The more power you want to use overnight, the larger the bank of batteries you would need. Then, if you want to use conventional lights and TV's etc. you need an inverter and regulator.
    FOLLOW UP: OH,yeah, google is alive with info on this. Here is just one link:http://store.altenergystore.com/Win...outhwest-Wind-Power-AIR-Industrial-12V/p3960/
    Just to throw out some round numbers, it looks like a 400 watt generator can be had for a grand. A battery which stores 1KWH runs a couple hundred. ( 1kwh is the power consumed by a 100 watt light bulb burnig for 10 hours.)
    There are other necessary accessories, but this gives you an idea.
  5. jadnashua
    Popular Science had an article in the last year or so about a ready to connect wind generator...supposedly installed for around $10K. One big enough to do justice may need to be high enough to get away from some ground effects and shielding from surrounding trees and other effects. Many places have a height limit in the local codes, so you need to overcome that hurdle first. Also, keep in mind that charging lead-acid batteries produces H2, which needs careful management or the house blows up...it is very difficult to see a hydrogen fire. Sometimes, it is just easier to hook it up to send back into the grid. It either slows your meter or reverses it if you are making excess. You can eliminate the battery bank unless you want it as an emergency backup rather than just a means to reduce your costs. Most if not all utilities have rules imposed on them where they have to buy your excess electricity. The rates may not be great, but it's better than nothing.
  6. Backglass
    Backglass New Member
    Jun 6, 2007
    New York
    Speaking of alternative power, anyone have any experience with solar panels for generating electricity?
    Have they reached the point of efficiency where it's worth the initial cost?
  7. CHH
    CHH New Member
    May 25, 2007
    Denver, CO
    As I understand it, so far the PV's still need substantial rebates from utility companies and/or tax credits to be worthwhile in an economic sense. They can be competative for off grid installations where the cost of bringing in a service line is substantial.
    The local utility started offering rebates so I've been browsing costs but not looking at the numbers real hard yet.
  8. Backglass
    Jun 6, 2007
    New York
    It was THIS THREAD on a pool forum and his 10kv array that got me thinking about it.
  9. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Connection to the grid sounds like it may be better than batteries. If you have access.
  10. alternety
    alternety Like an engineer
    Apr 2, 2006
    Washington
    Check out home power magazine on the web. http://www.scoraigwind.com/ for classes. otherpower for stuff and forums. These people actually build their own generators and blades.
    You will need a tower of some sort. I believe the windmill should be at least 10' above anything that will interfere with wind and cause turbulence (e.g., trees). Note that trees grow.
  11. HandyAndy
    HandyAndy General Contractor, Farmer
    Apr 17, 2007
    Haxtun, CO
    http://www.bergey.com/
    lots of information here, and one of the best wind turbines made today in the US. both grid tie and battery inverter types,
  12. molo
    molo Member
    Sep 23, 2006
    Cold New York
  13. alternety
    Apr 2, 2006
    Washington
    About all the power levels would accomplish is running an LED flashlight or maybe charging some smallish batteries.
    Not too exciting unless you have some low power application you need to run while using the stove.
  14. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Many areas have rules that require the utility to offer "net-metering" where you pay for the difference between what you produce and what you use. When you have demand exceeding production you draw from the grid; when you have production exceeding demand you "sell" to the grid.
    If you look at your electric bill it will tell you how many kWHr you use. Lets say you use 720 kWHr in a month, or an average power of 1 kW. But wind power generally produces on the order of 25% of the rated power of the machine because of variation of available wind.
    So you would need a 4 kW generator to produce and average of 1 kWHr.
    If that 720 kWHr costs you $1000 per year, you might break even if you could get a 4 kW rated generator installed for $10,000 and you could depreciate it, maintain it, and pay the interest for 10% of the cost.
    I think you would have a hard time achieving those numbers.
    The government (that is all of us, via our taxes) pays 1.5 cents per kWHr subsidy to companies that produce wind power. That is why you see so many wind-farms in places that have wind.
  15. Mike50
    Mike50 DIY Senior Member
    Jan 8, 2006
    Southern California
    oh by the way......
    We have an enormous windfarm nearby. Tourists are in awe and snap photos along the roadway. They think it's great that, thats how we power our homes
    with wind turbines. WRONG.
    Newsflash: The windfarm company sells it ALL to the grid. WE are stuck with all the windmills which many claim are eyesores. They also kill birds.
    I'd would be OK with the adverse issues if I could take advantage of this power
    but I can't, so I'm not.
    And another thing---for anyone that thinks this is part of some cool green ecologic
    thing. You can think again. The windfarm gets bought and sold to the highest corporate bidder now and then. Truth be known-they are actually almost as bad as the oil companies. They could care less...
    and so it goes......
    Mike
  16. BrianJohn
    BrianJohn DIY Senior Member
    Jun 22, 2007
    VA
    Some thoughts on batteries,
    You need enough battery to carry you through NO WIND periods, this can lead to a sizable investment, in addition sealed lead acid batteries have a usable life span of 3-5 years depending on number of discharges, depth of discharge and recharging current and times (should you start a recharge and then have a discharge). But wind coupled with solar may be viable, still need the battery, but between old sol and the wind the battery will see less discharges.
  17. alternety
    Apr 2, 2006
    Washington
    I think people that have any moderate sized system (wind, solar, probably not hydro) use non-sealed batteries. You can get some real monsters. You can get automatic rewatering caps.
    The care and feeding of batteries is non-trivial. Modern electronics takes care of some of it. The larger percentage of full charge you remove the shorter the overall lifetime of the batteries. So you need a lot more capacity than you think. You can find numbers for this on the web. I am not positive but I think 50% discharge is a common limit.
    Charging must be done carefully. Every so often the bank of batteries will need an "equalization" charge. They are charged to bubbling to bring all the cells to close to the same state. Each cell in a battery will have some variance from the others.
    If you are serious about it you really need batteries designed for this service. For small systems lots of people use things like golf cart, marine, or fork lift batteries. Lead-acid is by far the most used type.
  18. BrianJohn
    Jun 22, 2007
    VA
    Batteries are designed and sized first on the type of discharge, for example short duration high current such as engine starting batteries or for power distribution longer duration low current such as you might use in a solar application. When purchasing batteries you determine you load (or expected load) and duration of support time you require. You need not concern yourself with. The manufactured data is based upon your expected shut down voltage, the lower the voltage you discharge a battery to the more capacity but this shortens life. For long duration discharges the typical shut off voltage of the system is 1.75 Volts per cell.
    If you are serious about this get the PRPOER BATTERY for the application, the plates in a battery are designed for the particular application.
    As for sealed versus flooded, the industry is moving away from flooded cells in smaller applications as there is less maintenance and handling of the open jars and off gassing is not as big an issue.
  19. marchse
    marchse New Member
    Jun 11, 2010
Similar Threads: power generation
Electrical Forum discussion & Blog New Outlets= Erratic Dimming Power Jan 10, 2017
Electrical Forum discussion & Blog Another question: generator power necessary for 1/2 hp pump jet pump Oct 8, 2016
Electrical Forum discussion & Blog GFCI tripping with no load when connected to power Oct 7, 2016
Electrical Forum discussion & Blog Lost one leg of power need help. Aug 4, 2016
Electrical Forum discussion & Blog Intermitten (shuts off randomly) power to one side of electrical bus bar Jun 25, 2016
