Pouring Concrete floor over ABS Drains?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Rocknroj, Dec 30, 2008.
  1. Rocknroj
    Rocknroj New Member
    Dec 30, 2008
    I am installing new waste lines with ABS in my basement as part of a new bath. I am looking for advice/guidance regarding making certain that the lines do not shift/settle as a result of pouring the concrete floor.
    I am currently down to a clay/sand mix. I was going to lay a moisture barrier down, then gravel and then the concrete. I also have considerable water puddling in my dig area..
    Any help is appreciated.. Thanks.
  2. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    Make sure you first get it inspected. Put the gravel down, then plastic barrier, and finally pour cement.
  4. hj
    pipes
    You are supposed to pin, tie, or otherwise secure the piping so it CANNOT move once you have it in place.
  5. Rocknroj
    Rocknroj New Member
    Dec 30, 2008
    securing abs under concrete floor
    Any recommendations on best how to do that.. The soil is a clay/sand mix with lots of underground water. I have seen pictures with wooden stakes and metal strapping, but I don't really want to use wood as it will rot away and leave substantial voids.
    I have been looking all over and all I can find for groundwork is a sandy bed with the pipe laid in the bed about 1/3 deep and then covered with gravel..
    Thanks
Similar Threads: Pouring Concrete
Plumbing Forum, Professional & DIY Advice Questions on pouring concrete around new rough-in Aug 28, 2008
Plumbing Forum, Professional & DIY Advice Pouring concrete around/over yard cleanout drain Aug 4, 2008
Plumbing Forum, Professional & DIY Advice Toto CST714 Caorusoe toilet loud noise and won't stop pouring water Jun 14, 2014
Plumbing Forum, Professional & DIY Advice Generator sound, water pouring in under house Mar 23, 2014
Plumbing Forum, Professional & DIY Advice Sealing pipe through concrete Feb 24, 2017
