Will C.
Replacing the shower drain, 1. do I pour concrete just around the vertical riser(rough in) then use a inside cutting tool or something similar bc the drain I have the riser goes into the drain. or
2. should I cut the riser and install the clamping drain to the riser before pouring the concrete.
3. the height of the drain should be 1" above the new poured concrete?
thanks for any help!
